Delta 46-460
Delta 46-460
Jerry Louden
Delta 46-460
Jerry Louden
I am having trouble with my Delta 46-460. When I turn it on, it runs intermittently as if there is a faulty on and off switch. Now, it pretty much doesn't run at all when turned on. I have taken it to whom I think is a reliable mechanic to see if he can determine the problem. He thinks it is in the speed control area and has attempted to order parts. Delta is telling him what he needs is discontinued. To replace the entire box will cost as much as I paid for the lathe 8 years ago.
I guess the first question is, have any of you experienced the same problem and if so, what did you do? Also does anyone have a suggestion for a parts source other than delta?
I am pretty much out of my element with these complicated electronics so any help or suggestions will be appreciated.
I would have no problem taking the lathe to another mechanic in the Chicago area either, if any one has a suggestion here. Thanks
Re: Delta 46-460
Re: Delta 46-460
JohnV
I had this problem with my controller. Find an electrical motor repair shop that is certified for Baldor repairs. A local shop in Kansas City area fixed fine and thoroughly checked it out for about $100 labor charge. It seems that The controllers on these lathes had some quality control problems with "cold solders"
Re: Delta 46-460
Re: Delta 46-460
mikeee12345
Based on a few specs I looked at for this lathe, it uses a 90VDC 1HP 1725RPM motor and a DC speed controller to adjust the speed of the motor. If Delta no longer supports this equipment you might be able to retrofit to a generic DC speed controller that is rated for your motor HP and load application. The other option would be to have someone troubleshoot the DC controller to determine the component that has gone bad. Most electronic repair shops would be able to diagnose the problem with this type of controller which is very commonly used for various applications. Grainger sells a generic 90VDC speed controller which would work for your application.
Re: Delta 46-460
Internet is awash with this issue since day 1
Dick Coers
The electronics have been an issue with that machine for a long time. Bad potentiometer, bad solder joints on the control board, dust in the switch, bad reverse switch. Delta has always blamed the issues on people overworking the lathe when doing large bowls. Last I read, Delta has parts now in stock. It took them forever to start carrying parts. There is a type 1 and a type 2 version of that machine. Type 1 had the switch more to the back and constantly broke during shipping. Type 2 has the switch on top.
Sawdust in the switch is the problem you hope for. Do some disassembly and hit everything in the box with compressed air. I think you can disassemble the main with to clean out the inside.https://thepatriotwoodworker.com/forums/topic/19773-delta-46-460-repair/
Re: Delta 46-460
Re: Delta 46-460
Bill Boehme
The most likely part to fail on anything is a potentiometer (the speed control in this case). If you don't mind spending a few dollars on a new speed control pot you have a high likelihood of saving a huge amount of money in getting unnecessary parts. Don't get the pot from Delta, you can save a lot of money by getting it from an electronic components distributor. Mouser is a local place here that also sells through the Internet. The symptoms that you described are a pretty good indication of a failing pot.
Re: Delta 46-460
A mechanical variable pot is the most ......
JamieDonaldson
...potential wear failure part in speed control circuits on most lathes with a rotating speed control knob. I have seen many turners who use that pot for an ON/OFF switch, vastly accelerating the potential for wear failure, so use the ON/OFF switch instead, as intended!
Re: Delta 46-460
Anyone ever use contact cleaner successfully?
Dick Coers
Ever since these things started having electrical problems, I've held my breath. Just the perfect sized machine for the ornaments and small work. I had one Jet dust collector that I was able to take the switch apart to remove all the dust, just wondering if the pot and switch can be easily disassembled for cleaning on the Delta?
Re: Delta 46-460
Re: Anyone ever use contact cleaner successfully?
I've had good success with contact cleaner on pots. Not always on switches unless I dissassemble them some although it worked like a charm on my dust collector remote the other day.
