finishing
art demers
Just finished sanding a bowl NP to 400 now I was going to use sanding sealer but I want to try Yorkshire Grit so do I use grit first or sealer first or neither. Maybe it doesn't matter Hopeless !!!
finishing
art demers
Re: finishing
Ron Bauer
Do a test piece.
Answer in the first sentence *LINK*
Dick Coers
But, I'm surprised you would want a coat of beeswax on the wood before applying any finish. Never heard of it, never used it.
http://yorkshire-grit.com/Product-Page/
I can't imagine any successful attempt.........
http://JamieDonaldson
....at applying a "regular" finish over the ingredients of that Yorkshire Grit that contains mineral oil and beeswax.
Re: I can't imagine any successful attempt........
Dick Hines
"Bees Wax" That should tell you something. I don't think any finish will work over wax. I am just saying.
Want to polish wood or finish?
Ken Vaughan
Washing with mineral spirits will help remove wax and mineral oil
Have you ever wet sanded with wax??? Good cleaning afterwards works.
I remember Russ Fairfield advocating wet sanding with wax, but having distaste for mineral oil because it softened finishes.
I would use it to polish the finish, but experience with other wax grit combos has been blah so try it on something it cannot degrade.
Re: finishing *LINK*
john in lutz
Mike Waldt uses Yorkshire grit on almost everything he turns. He uses a sanding sealer, half lacquer and half thinner, before using the grit. Then after the grit he uses various wax finishes. No film finish.
So if you are wanting to a wax finish then his stuff is good. I prefer film finishes, shellac, lacquer, or poly so do not use anything in prep that contains wax. Sometime I sand with walnut oil but let is dry at least a week before sealing with shellac.
This is one of Mike's videos on the product.
https://www.youtube.com/watch?v=jPe6cBtsJjs
Wood Turning - Yorkshire Grit Review
Re: finishing
art demers
I did try the sanding sealer yorkshire grit. it took out almost all the finer scratches out then I used mylands finish turned out very well very satisfied .thanks for your input Art
