Jet 1642 VFD Programming
CJ in MPLS
Anyone have the VFD codes for a Jet 1642 EVS handy? I have a replacement VFD and no codes. I'm slowly learning which codes might actually work, but shortcuts would be welcome.
Cheers,
CJ
CJ in MPLS
Cheers,
CJ
Re: Jet 1642 VFD Programming
Dwight Rutherford
Send me your E-Mail address, I’ll send you the codes.
Dwight
For 115v version of 1642
Jet 1642 VFD parameters Delta VFD-S series, 115 volt version
(I made a note in my manual that this is VFD0075S11A style as shown on pg c-12)
These three parameters are read-only, perhaps are hardwired
0-00 4 (identity code, read only)
0-01 4.2 (capacity in amps, read only)
0-06 2.3 (read only)
These are the parameters different from the defaults
All other parameters are set to factory defaults according to the Delta manual
1-00 132 Max output frequency
1-01 60.0 Max voltage frequency
1-03 5.0 Mid-point frequency
1-04 20.0 Mid-point voltage
1-05 5.0 Min output frequency
1-06 20.0 Min output voltage
1-09 5.0 Acceleration time
1-10 5.00 Deceleration time
2-00 1 Master freq determined by analog signal 0v-10v
Position of jumper J1: top two pins for voltage signal input
2-01 2 Operation, keyboard stop disabled
4-09 1 Enable line start lockout
6-00 0 Disable over-voltage stall prevention
6-01 390 for 230v series (should be factory setting)
6-08 1 Present fault record: over-currrent
6-09 1 Second most recent fault: over-current
6-10 1 Third most recent fault: over-current
7-00 120 Motor rated current
-----end-----
Re: For 115v version of 1642
CJ in MPLS
Thanks John.
As soon as the new potentiometer shows up, I'll program the VFD.
Cheers.
CJ
