Vocabulary - "Fingernail" and "Swept Back"
Don Stephan
So many times I have read descriptions of spindle and bowl gouges with a "fingernail" profile or grind, and a "swept back" grind, but never documented with side and overhead views. I try to sharpen (I'm a heathen freehand sharpener) my spindle and bowl gouges with a slight convex curve along the tops of the sides of the flute. I create this convex curve by placing the end of the flute on the grinder with the flute facing the grinder, and gently rock along the sides of the flute. Then I grind the sides of the flute until there is a sharp cutting edge at the tip (or nose) and along each side or wing.
But I don't see any resemblance when I compare one of my fingernails with the end of the gouge, neither side or overhead view. Does anyone recall seeing a labelled photo showing why this shape at the end of a spindle or bowl gouge is a "fingernail" profile or grind? Same question for a "swept back" profile or grind.
How in blazes are we to learn and mentor with undefined vocabulary? Grrrrrrrrrrrrr and haruuuuump.
