Suitable species for a goblet?
AZ in Colorado Springs
A friend asked me to turn a goblet for him (picture the one Indiana Jones selected at the end of one of those movies -- not too elaborate).
What's a good species of wood to use?
And what finish to make it water proof? (I don't know if he wants to drink from it or not. I'm wondering if there is a magic fix for this?)
Thanks
Re: Suitable species for a goblet?
Bill Howatt
I've made some end-grain turned goblets with hard maple. Any close grained hardwood should be fine. Because there is a lot of short end-grain the liquid does tend to weep alright even with close-grained wood. I just used some polymerized tung oil which I likely got at Lee Valley for the finish and to seal them. Any film finish would work.
Bill
Thanks, Bill
bill tucker
To seal the inside, try using 2 - 3 light coats of CA glue. Will seal the inside and is impervious to most common liquids.
Thanks Bill T
Any close grained wood should work. It's the finishing that makes it truely work. My friend Jim Rinde has been doing experiments and has found the best finish to date. Soak the inside with thin CA. He pours some in and spreads it around with a plastic glove on his hand. Then wipes it out if necessary. Let it dry. The sand it lightly. the soak the inside with melted Carnauba wax. He simply puts some flakes in and fills it up and puts it in a small oven, if I remember correctly it was 250 degrees but you might have to sneak up on the temperature. You want it just hot enough to melt it but not too hot. As it melts add more until the goblet is full. Let it sit for 10 minutes and then pour it out. Wipe out the inside and let it dry. This method has proved to not leak and not stain.
the other method not quite as good is to coat the inside with System 3 mirror coat, let it sit and then wipe it out.
Thanks, JL. I appreciate it.
