A55 Smoothing Plane
IPE box
IPE box
IPE box
I turned this Tuesday morning. It was a piece of wood about 6x 12 that had cracks everywhere. I almost threw it away many times but kept it around to show people what kind of wood not to bring to club meetings to give away. All the cracks were highlighted by my friend John K Jordan. Looked pretty useless but I needed some wood to play with hand chasing and thought there might be a 1 or 2" square piece that I could get out of it. I sliced it about a third of the way from the top and it appeared to be pretty solid inside. I can another slice off and then cut 1/2" off all 4 sides. Appeared to be pretty solid so I did some hand chasing. chased threads OK without too much chip out. Any way I decided to make a box a lid out of the rest. The checks went about an inch or so into each end so I made my tenons for the chuck on that end. Turned the box and then the lid. I hollowed the box with 3 Hunter carbide tools. I've included a photo. There is no sanding inside at all. Wish there was a better way to photograph the inside but you have to cut it in half to do that. I threaded the box using the Baxter threader. In the photo it looks like the lid doesn't fit correctly but it joins the base perfectly in real life.
Re: IPE box
Beautiful!
klowwn
You are always an inspiration! Wish I could afford the Hunter tools so I could get that good of a finish inside a box (even if I had to do some sanding :))
Ricc
Re: IPE box
Re: Beautiful!
Ric Although they are nice, I've turned about a gazillion boxes long before I had the Carbide tools. Even before negative rake scrapers. Right now a good negative rake scraper and a light touch will do box interiors nicely. These Hunter tools because they are bevel rubbing tools do have a learning curve. Not bad but it takes a little effort to learn to rub the bevel and get clean cuts. Well worth the effort.
Re: IPE box
Re: Beautiful!
klowwn
Thanks for the info. I've been watching the Neg Rake Scraper discussion over on AAW's site. Only have one 3/4" scraper so I haven't decided yet if I want to save money for a neg rake one or make mine into one.
Ricc
Re: IPE box
Re: IPE box
jorge
Good work as usual John,
I did lay an enormous ipe deck in a resort, and it was a different color, tan with black, very hard. It most be something like the Philippine mahogany that are a whole bunch of different species bundled.
