Veritas - Innovation in Tools
Festool DC
Festool DC
Festool DC
JohnV
I recently downsized and am setting up my Lathe in my new basement shop. I use a Festool vac to collect sawdust when sanding my turnings. I've been thinking about using a system live the Dust Deputy to collect some of the larger shavings. Oneida will not recommend any system other than one designed specifically for the Festool Vac. They warn that static buildup can harm the electronics in the vac unless a continuous ground is maintained from the point of collection to the vac which has antic static system built in. Is this a real problem or company self protection fear. The basic Dust Deputy is about $50 the Festool specific kit is $300. I don't want to destroy my Vac, But I also don't want to spend $300 if I don't need to.
Any thoughts on this? has anyone set up a cyclone collection with a Festool ? If so did you set up a static discharge provision?
Thanks,
John
Re: Festool DC
Re: Festool DC
mikeee12345
Electrostatic discharge can be a real problem especially when you are moving
a volume of air with particles in the air stream. These voltages can build up to high
levels that can discharge across sensitive electronics or bearing races. You need to
provide a ground path for these voltages to shunt the voltage to ground. Bonding
all of the components of the system together and making one equipotential plane
and bonding it to a good ground in your shop should provide what you need. Making
all of those component bonds can also add up in cost if you don't have a good source
and have a good way to bond all of the components together.
Re: Festool DC
Re: Festool DC
You can buy a Rigid or other cheap shop vac that has good suction and use it with the cheaper version of the dust deputy cheaper than buying the Festool version.
I used a Rigid shop vac for years and finally bought a Festool Vac, not because it was more powerful, but because it would fit in a cubby hole in my tiny shop.
Re: Festool DC
Re: Festool DC
Dick Coers
I don't think you'll have much luck sucking up large shavings with a Dust Deputy. Small inlet size and large curls won't play well together.
Re: Festool DC
Re: Festool DC
Don Stephan
Like Dick, I'm not sure your concept would work well with lathe shavings. Even for a smallish bowl or spindle, there can be a lot of shavings to empty from the collector. I have a large central dust collector and collect the shavings with a broom and shovel.
Re: Festool DC
Jim Barbour
Re: Festool DC
Jim Barbour
I am with Dick and Don regarding picking up shavings as they are created. It is nearly impossible with anything smaller than a mill-sized system. I have a 5hp Oneida and use it to collect shavings - via a broom and floor pickup with a 6" line. I am remarkably unsuccessful at catching them as they come off the lathe. Sanding, on the other hand,works fine right at the lathe.
