Goblets
Goblets
Goblets
Jorge
Out of the blue, I've got orders, one for 6 goblets and the other for 2 deeper and with more capacity and short stem, so to warm up I made one yesterday, it's been several years since last and it came more or less ok, with the state of my hands, when doing the bowl, I used to use a round scraper for the bottom and the Hunter tool for the sides, well, now I get catches with both I wish I had enough room to use the Kobra, but it is not an option at the moment
How do you sand the inside? I used to get smooth finish and never sanded.
How do you finish the bowl, so it is good for drinking wine? I used to use lacquer, it is that ok? Once I had a complaint about it, so want to hear your experiences. Thanks
Re: Goblets
Re: Goblets
Jorge
still playing with the proportions, stem too fat and base too heavy
How do you sand the bottom? Fingers short for the job
Re: Goblets
Re: Goblets
I knew someone who finished them with thin CA glue. They said that made them dishwasher safe. I doubt that and would not recommend putting anything wooden in the dishwasher.
To sand the inside, try using a smaller soft sanding pad on a mandrel with a larger disk with slits cut into the sides to make it fold up around the edges of the disk. I use a 2" mandrel with 3" sand paper. Hook and loop sandpaper.
Re: Goblets
Re: Goblets
Darryl Hansen
rather use epoxy or some sort of harder finish than lacquer. I leave the goblet on the lather running at slow speed till epoxy or
"bar type urithane finish" until it sets. For sanding something deep I use a surgeon clamp with the paper wrapped around it. I have a couple of them one is about 6 inches the other about 12. they are cheeeeep.
Re: Goblets
Re: Goblets
Jorge
Thanks Barry
Re: Goblets
Re: Goblets
Jorge
Thanks Darryl, I remember Carole recommending that long ago, but around here nobody carries the hemostats. Where do you get them?
Re: Goblets
Jim Barbour
Re: Goblets
Jim Barbour
Ditto Darryl on both the epoxy and the hemostat. I have found Smith and Co. thin epoxy sealant to work well. I get it through Star Distributing, but I am sure there are other dealers as well.
Re: Goblets
Re: Goblets
Be careful with Hemostats. DO NOT stick your fingers through the holes in the handles. If it takes it away from you it can twist them up badly.
Re: Goblets
Re: Goblets
Jorge
Thank you Jim
Re: Goblets
Re: Goblets
Jorge
Thank you Barry
Re: Goblets
Jim Barbour
Re: Goblets
Jim Barbour
I have taken sugru (a malleable glue) and completely filled the finger holes on my hemostats I use for sanding so it is no longer possible to put my fingers through them.
Re: Goblets
Re: Goblets
Roger
Try long nosed needle nose pliers with the sand paper on a 2" interface pad. Don't know what your hand problem is but I've lost most of the feeling in the thumb and first two fingers on each hand, and this has worked well for me. Good luck.
Re: Goblets
Re: Goblets
Don Stephan
For several years my finish for wooden bowls has been a wiping varnish made by combining equal parts good quality mineral spirits and Pratt & Lambert 38 alkyd varnish. I mix small quantities in a quart paint can, but it starts to thicken in about 3 days. I'm finding a Stop Loss bag works well for the varnish itself, I haven't tried putting the mix in a Stop Loss bag.
Using a bit of rag, thoroughly wipe on (several times quickly) the first coat, immediately scrub as dry as possible with clean paper towels, and dry overnight on a nail board. Succeeding coats wipe on a wet coat, immediately scrub dry with clean paper towel, and dry on a nail board, two or three coats a day, until desired sheen results.
My red oak cereal bowl now has 25 months of daily use, and I wash with the soft side of kitchen sponge and a drop of mild liquid dish soap, towel dry.
If you can't find P&L 38, you might look for another brand of alkyd varnish.
Re: Goblets
Re: Goblets
John C Lucas
I use the Hunter #4 to finish the inside and just barely have to sand.
Re: Goblets
Re: Goblets
Jorge
John yes, I used the #5 Hunter and had a smooth finish, I had a stroke in 2012 and as results lost my grip in my right hand and my hearing on the left ear, then arthritis got really bad, by2015 my right hand was quite useless, I have improved a lot since, but between the bad grip and the painful joints, I cannot use a scraper or the Hunter these days.
Re: Goblets
Re: Goblets
Jorge
Thank you Don, I'll look for it
Re: Goblets
Re: Goblets
Jorge
Thank you Roger!
Re: Goblets
Re: Goblets
John C Lucas
Do you use a negative rake scraper. They require almost no force to do their job. With a long handle you would have plenty of leverage to hang it over the tool.rest far e ough to do a goblet.
Re: Goblets
Re: Goblets
Dwight Rutherford
Harbor Frieght has hemostats, regular size and giant size.
Re: Goblets
Re: Goblets
Jorge
That is an idea, I'll have to make a long handle and mabe a tool rest as well, the kind that goes inside the bowl Thank you
Re: Goblets
Re: Goblets
Jorge
Thank you Dwight, good to know
Re: Goblets
Lyle Jamieson
Re: Goblets
lyle Jamieson
OK I see it clearly now. Go back and revisit the Kobra system option. It will take all the work and fear of catches. If you are getting catches with the Kobra look at my setup instructions and pretend you got it from me. My system with the Hunter carbide cutter in slicing mode (not scraping) will leave it with no sanding needed. The Kobra should be able to do the same. If you have the laser it will save you a lot of time, also and get your wall thickness uniform. A captured bar will be able to get into the same small sizes, like a goblet, as you can reach with hand held tools.
Re: Goblets
Re: Goblets
William Duffield
I think I knew that intuitively, but it sure doesn't hurt to be reminded again, explicitly and in no uncertain terms. I usually have a couple hemostats attached to my lathe bed or head or motor with rare earth magnets. They're great for holding synthetic steel wool for sanding and for applying finish.
Re: Goblets
Re: Goblets
Jorge
lyle, I am in a provisional mini workshop and have very little space, cannot set up the Kobra or stand in the other side of the lathe, the problem other than limited space are my hands. Thank you
Re: Goblets
Re: Goblets
Inside: I try to cut cleanly then clean up with either a Hunter tool, a Sorby teardrop scraper, or with a small hand-held curved cabinet scraper. Then sand with 320+, some with the lathe slow but most by hand. Insides are smooth as glass with no tool marks or scratches. I know nothing about finishing to hold liquids.
I don't think I have any photos of the insides of goblets but this is the shape of the last one I made:
For my design "mistakes:
One in progress with a larger cup, stem a little fat:
I think the base on this one is a bit too big:
