New walnut mirror
This is really different than what I've done before although the texture is the same.
New walnut mirror
Re: New walnut mirror
Ed Davidson
Lots of texture and back-to-nature style with that one, John...very cool.
mark paulley
John, Do you mind explaining how you textured the pieces? Wire brush?
Thanks
I use a V tool carving tool to first cut the grooves. Then I use gouges or my Dremel to round over the "beads". The I use a wire wheel in the drill press or lathe to cut the texture. You have to find the right wire wheel. I usually buy the cheap ones from Harbour freight in a couple of varieties. ONe of them will usually be the right stiffness for your particular wood. Softer wheels produce a finer texture. When I have that done I use a V shaped riffler file to cut the very bottom of the grooves for a cleaner look. Then I follow this with a soft brass brush. I usually use Krylon Fixatif as my spray finish for this texture. I learned this from John Jordan.
mikeee12345
Nice work John!
That one really stands out with it's natural design and texture!
Thanks for the explaining the process!
richie croce
That is Really thinking out of the box. Your work is inspirational.keep it comeing.
Philip Duffy
Stunning, John, just plain stunning! Phil
Wow!!
Stunning break from "the routine."
George Guadiane
I really like this. Thanks for taking the risk, I think it paid off.
Don Orr
Very cool! Gives me a kind of a "Middle Earth" feel.
