THE WOODRAT IS BACK!
Another question on sharpening angles
When you measure a scraper angle and say it's has a 70 degree relief. As measured from the top do you call it 70 degrees or 20 degrees. My machinist friend says he always measured from vertical so the question above for him would 20 degrees but then I said is that a negative relief or positive. He didn't have a good answer for that.
If you have a negative rake scraper and your measuring the top angle again measured from the top and it's 10 degrees would you say 10 or some other angle. Again just trying to get the language correct.
when I measure the angle on a bowl gouge I put one arm in the flute and then measure the angle down. In my case my bowl gouge is 55 degrees. It would be 35 measured from vertical, 125 if measured from the bottom. To me the included angle is more important on a cutting tool which is why I measure from the top. 55 degrees is the cutting angle of the sharp edge of the tool.
Re: Another question on sharpening angles
Reed Gray
I noticed that about machinists a while ago, they measure differently than we do.
The one I wonder about is with negative rake scrapers... If included angles mean both top and bottom bevel angles, if I have a skew type that is 30/30, then included angles are 60. If I have a standard scraper with a 70 degree bevel, then is it a 70/0 and therefor, included angles are still less than 90 degrees to fit into the ideal range that Stuart and others prefer????
robo hippy
John C Lucas
Thats the way i understand it Reed. I actually played with both today. I needed to make a regular scraper for a.photo i was doing. After the photo i compared ot to my negatice rake scraper.that has the same 70 degree included angle. Couldnt tell a h #ifference in cut quality but the neg rake was much more forgiving and less grabby.
If writing something like an article this subject begs a good diagram!
How I think of it: In geometry an included angle is the angle between two sides of a triangle. We can consider all grinds with flat bevels identical, varying only in the number of degrees in the included angle and how much the triangle is "tilted" relative to the axis of the tool shaft.
We measure from the "horizontal", the top edge of the tool shaft (or the bottom of the flute for a gouge). The angle of a conventional scraper would be 90-deg if ground straight, 80-deg if the ground face is angled back 10-deg. The cutting angle of a scraper, NRS, bedan, skew, or gouge is the included angle.
The skew and standard parting tool normally have equal length bevels so the angle from the horizontal of one bevel is 1/2 the included angle. A skew with one side of the triangle aligned with the axis of the tool shaft is the same as a bedan (or we might call it a scraper depending on the angle). I use the angle from the horizontal to the upper bevel. A cross section through the tip of a gouge is also equivalent to a bedan. A side edge of a gouge is harder to measure since one side of the "triangle" is curved. The NRS needs another number to describe how much the triangle is "tilted" - I think it should be defined by the included angle and the angle of the top bevel from the horizontal.
That's the way I think of these angles.
Picture of measuring a gouge bevel angle.
https://22293-presscdn-pagely.netdna-ssl.com/wp-content/uploads/12355_5F00_trad21.jpg
Chuck Engstrom
That little General protractor is just the right thing for measuring angles on our tools, and they're available on ebay for about $10-12, even less for "pre-owned," in several variations -- search on "General protractor." I carry one in my tool chest when teaching, and there's another parked permanently next to the grinder.
That's what I use but I have at least 5 other ways to measure a flute angle. I don't really worry about sharpeness angles other than to answer questions for other turners or in my investigation on what angles produce better cuts. On a bowl gouge anywhere from 40 to 60 degrees will work. With 60 you get into a deeper bowl and still rub the bevel. With 40, not so deep but you get a cleaner cut because a more acute edge simply cuts cleaner.
Lyle Jamieson
Totally agree
Reed Gray
I played around for a bit, after watching Nick Stagg from Salem demo. He used a standard scraper with the burr honed off. It works great for hard woods, but not so good for softer woods, and I was using sugar maple. I won't put a standard scraper any where near the edge/rim of a bowl that has been hollowed out unless I am doing a shear scrape. though I have seen some use this method. I am also playing around with an 80/25 NRS like the 'hardwood bowl NRS' that Sorby makes. You use it for a peeling type cut on bowls, so you are rubbing the bevel. Makes my sphincters pucker to try it out, but it does a really nice job. Anything to reduce sanding time....
robo hippy
Jesper, Denmark
Re: My personal take on this.......
Jesper, Denmark
With a single bevel tool, always measure the angle between the c/l of the tool and the bevel - because this what you CAN measure directly. You cannot measure the angle between the perpendicular to the bevel directly.
With double bevel tools, you can measure the included angle directly - and that is what you are interested in.
