Finish for Olive?
Finish for Olive?
Finish for Olive?
I'm cutting into a slab of Mediterranean Olive to make a wedding present (for a girl I've known since she was 4 years old!)
Has anyone used oil on Olive? I generally prefer the soft sheen of multiple applications of oil, such as Watco, but I've never tried it on olive. Will it darken it excessively over time? I know that watco oil doesn't play well with some woods - for example I put some on a beautiful piece of Cocobolo once and within 6 months it was almost as black as ebony. I'm doing some tests with different finishes but I don't have 6 months to wait - the wedding is in December! I've also used beeswax for these, melted into the surface with a heat gun, so that's another option.
I've heard that some finishes like lacquer and poly are less likely to react with the wood over time and I've used them but for something that will be used for food I don't want a film on the surface.
I wiped on naptha on a section of the bottom to see how the oil might bring out the figure (sanded only with a bit of 220 by hand here):
Naptha doesn't add any color (it's like putting water on it without the drawbacks of water) so the browns and yellows in this picture is about what it would look like with oil. I applied oil to some sanded scraps a little while ago and the wood looks just like the photo.
BTW, if you haven't used naptha, maybe try it. It doesn't affect the wood or any finish applied later, wipes away sawdust and sanding grit, doesn't raise the grain, and drys very quickly. Besides showing what the finish might do to the figure in the wood it helps me see hard-to-see sanding scratches, tearout, and other defects.
Any turners of Olive hanging around?
Re: Finish for Olive?
John I've been using Minwax wipe on Poly now for several years and I don't notice any color change over time. It does darken the wood about like it looks when you apply mineral spirits but does not yellow as much as oils. Some think it looks blue but i don't really see that.
wop
Does the wipe-on poly soak into the wood like oil or does it make a hard film on the surface?
Re: wop
I made some knobs for drawers out of tiny pieces of olive. I finished them with lacquer and they are beautiful. I know this does not answer your question.
You mentioned a food safe finish. On cutting boards and salad bowls I have used safflower oil. I think Russ used to recommend it. Supposedly it will not go rancid, and it has very little odor and taste. I have pieces that are years old and they have not darkened significantly. Might try warming it and adding a bit of bees wax. I think I would do that on a scrap.
ebd
ebd
Gosh that's beautiful - both the bowl and the wood color & figure.
Re: wop
mikeee12345
I usually use Boiled Linseed Oil or Teak Oil on Olive wood.
These are easy finishes which can be maintained by a quick re-application of oil.
Re: Galaxy planet mirror
Ralph Watts
John, for a non-flim finish, I use wipeon Polly by applying the polly until the wood won't take any more. Then wipe everything off and let it dry. A durable non-finish finish.
regular poly
Dick Coers
I've been using full strength Minwax poly now instead of the wipe-on. It feels like they reduced the viscosity recently. While doing some spinning tops, I tried using it like a friction finish. It worked out great. With a little friction, it was dry to the touch when I parted it off the lathe.
Thanks for all the options. I'm less worried about it now. I finished the turning today, scraped the inside to a perfect curve then sanded with 320 and 400. I have scraps for some more tests. The wood is special and the friend is special - don't want to mess it up!
>>>ebd: Gosh that's beautiful - both the bowl and the wood color & figure.
Thanks! I got that wood from our illustrious leader Ellis. When I cut into the slab it looked fairly bland compared to other olive I've turned but whoa, it really popped when I wiped on some liquid!
I don't often make more than a couple of one thing but these have been so popular I've make a pile of them so far from a variety of woods - just need a 1.5-2" board about 9x9". Some are flatter and some dished more, what ever I feel like at the time.
I've been giving them mostly for wedding presents but took this one to Italy to give to our friend whose family took us all over northern Italy for a week-long private guided tour. The wood for this piece was from Ellis too! (picture posted before)
I'd LOVE to find some more like this!!! The chatoyance was to die for.
mikeee12345
There is an Ebay seller out of California that has an olive farm that sells flat rate
boxes filled with short cut olive logs. These are smaller diameter logs around 6" in diameter.
If you contact him he may have some larger logs available, shipping will vary depending on
your location. A larger diameter 25# log ships for about $45.00.
Looks like I forgot to write that the wood in that last photo is figured maple. I've found more figured maple since but so far nothing anything like that piece.
I've made these little platters from cherry, cedar, black walnut, english walnut burl, basswood, and a few others. I have wood set aside to make one from myrtle, cocobolo, poplar, ambrosia maple, and sapele.
