new ornaments with chain
I was stuck in Walmart while my wonderful wife was shopping so I hung out in the craft area (DUH it's either there or the outdoor section) Anyway I had layed out a piece of ceiling fan chain to make an ornament with a chain finial. I saw the necklace chains and the crosses and I had to have them.
It's really hard to get the chain down a hole just big enough to fit so here's a tip. Hold the chain so about an inch hangs down. Then drip some medium CA on the last 1/2". spray it with accelerator. Now you have a stiff portion that's easy to get down the hole. Put some more CA on this section and then slide it in the hole and let it sit.
The one on the right end is an experiment and you will probably see more of those soon. Most of these ornaments are solid but I hollowed the Walnut one on the left end.
Re: new ornaments with chain
Don Orr
Great idea and execution John! You continue to amaze and astound.
David Walser
John -- Those are very nice. I like the chain finials very much.
Excellent! I am always blown away by your ideas. Please save all those photos and publish a book some day - you could inspire a generation of turners!
Can you thread a very thin wire on the last three links of the chain and pull it through? Or dip it in water and freeze it to make it stiff enough to push through (quickly). I thought of some crazier ideas but new one each seemed less and less likely to be useful!
I'll bet those necklace "chains" that look like tiny flexible ropes instead of a series of links wood look great too. I can't think of what they are called at the moment.
David Smith
Beautiful ornaments John. Great photography too!
