walnut tray
walnut tray
walnut tray
Ray Mtn. Home Ar.
It's about 10". Am getting an early start on Christmas gifts. Just using simple patterns, they go fast.
Re: walnut tray
Re: walnut tray
Ed Davidson
Very well done. I like the design...what method do you use for engraving the patterns?
Re: walnut tray
Re: walnut tray
Now THAT's interesting! Do you happen to have a picture of it from the side?
Re: walnut tray
Dennis in Southern Oregon
Re: walnut tray
Very nice! Is pattern wood burned?
Re: walnut tray
Jim Barbour
Re: walnut tray
Jim Barbour
Spirograph for the lathe! Who knew Hasbro Toys had expanded into turning tools ...
Re: walnut tray
Re: walnut tray
Dwight Rutherford
Really big Rose Engine?
Re: walnut tray
Re: walnut tray
Ray Mtn. Home Ar.
The side view you asked for. I edge glued a couple of pieces of 3/4 X 6 boards, glue a block on the back and chuck it up. I turn it in the lathe and then move the tray and chuck to the rose engine and cut the pattern.
Re: walnut tray
Re: walnut tray
Dwight Rutherford
Did you use the Lindow large eccentric cutter or one of your own manufacture?
Re: walnut tray
Very high cool factor.
