THE WOODRAT IS BACK!
my first shop and lathe
OK it's not my absolute first. I rented a house with a garage that had gravel floor and no door. I built a workbench that folded up and locked against the wall. My small collection of tools, a router, jig saw, and several hand tools all hung on the wall and were safely locked away when the bench was folded. that was my first shop. This one was second. I'm kind of guessing but it had to be 1980 plus or minus a year. It was in the back bedroom of a 2 bedroom apartment. I told all the neighbors if I ever made nose that bothered them to call and I would stop. Shortly after this photo was taken I purchased the new Shopsmith planer. Man what a noise maker. Still I never had a complaint from a neighbor. I had rigged up wooden supports to go around the small table so I could rip a piece of plywood to size by myself. I'm not a fan of the shopsmith when compared to quality tooling which I have today. However I did an awful lot of work back then. It deserves the honor of getting me into turning which of course is my love today. In my opinion the lathe is the worst part of this machine but nonetheless i made a lot of segmented bowls and clocks on that machine. When you compare this setup to my current shop which is which is 24 X 30 plus a seperate 23X10 room for parts, paints, and smaller dry wood storage there is certainly a huge difference. Not to mention that I have pretty much high quality stand alone machines now instead of this all in one machine. OH and I"m still using the small bench grinder in the lower right of that shelf. I purchased that from Sears about 1976 and still use it frequently. It's in my metal working area and has a course wheel for rough grinding and a Green wheel for sharpening carbide. That was the grinder I used for many many years to sharpen my lathe tools. 3450RPM and vibrates. It's a miracle I ever got a sharp tool.
Re: my first shop and lathe
Jim Barbour
Jim Barbour
Looks a lot like mine, only much larger. I was in an outbuilding and could actually touch both walls simultaneously. It was roughly 14'X6'. Not only could I not cut a full sheet of plywood, I couldn't lay it down! The Shopsmith and a circular saw were the only power tools I had so I sharpened on the sanding disk on the SS.
mikeee12345
My first shop was so small.
How small was it?
My first shop was so small I had to mount the lathe vertically on the wall to turn a spindle.
John C Lucas
Isharpened on the disc sander a lot. It has some great advantages. First if your using carbon steel tools you can sharpen toward the middle of the disc. You had a much slower surface speed toward the middle so you didnt burn the steel as easily. It ran true so it was wasier to control the sharpening than using my grinder with out of roud wheels. That was before i knew how to true up wheels.
Dennis in Southern Oregon
I dunno John, my shop has never looked that clean. Was this pix taken on day zero?
Sam Scalzo
My first shop was 8x16 and then I added 10x12.Still too small.I have all my tools on wheels and work outside a lot.
Don Orr
I love it ! Efficient and functional. Certainly making the best of what you have.
Pete in Holland MI
I was raised on a Shopsmith. After getting married, found a used on in the local classifieds. Bought it & restored/rebuilt it. After about 6 months, another surfaced in the classifieds for a price I couldn't turn down. Bought it, rebuilt & restored it, and sold it for a small profit.
Somewhere around the house, I have a picture of the two of them, side by side, in my earlier shop.
Did a lot of work with the Shopsmith for about 8-10 years, but eventually replaced it with individual stationary tools. Realized a Shopsmith is like Swiss Army knife. You have all the tools, but none are really as good a the real tool.
Pete
You can make high end work with one.
John C Lucas
My grandfather had a Shopsmith 10ER. He made incredible pieces of furiture for all of his kids. My dad took up woodworking after he retired and bought a Shopsmith. Ca t tell you how many pie safes, Hoosier cabinets and dressers he built. You do have to learn to deal with its shortcomings. Everytime i came to visit he would have something for me to turn. The lathe set up is definitely the weakest link on that tool but still you can turn.
