Krylon matte finish question
Mark Wollschlager
I sprayed a aussie burl piece with krylon matte clear over an oil finish.
I am pleased with the look. I wanted a clear flat look, rather than glossy.
The figure shows through without having to deal with reflections.
My question is more about the texture of the finish.
There is a noticeable texture, not orange peel, just not smooth.
Something to just deal with, or can the finish be smoothed with high grit?
I am under a bit of time constraint.
I wanted to get the piece done and left to sit till next week when it will be presented as a gift.
Better to leave it alone?
Most of the pieces I have with that finish have a texture so it was not noticeable.
Re: Krylon matte finish question
Dick Coers
Of course it can be smoothed. I don't consider any finish to be acceptable out of the gun or rattle can. You will need enough film thickness to work though. You will definitely need more than one or two coats out of a rattle can. I start at 600. If that doesn't cut the imperfections out quickly, I fall back to 320. I use foam backed abrasives for this work. I love Abralon for final effort.
George Balock
George Balock
Mark,
Most of the time I rub the piece down with 0000 steel wool to remove that texture. If I want a little more shine, I'll put a coat of microcrystalline wax on to bring up the shine.
George
The matte finish is by nature not.......
JamieDonaldson
....a smooth finish, and I suggest that a semi-gloss would be a better alternative.
hi Mark
GaryG in MD
You can achieve any level of shine from 'none' to 'very' from an oil finish by just rubbing it out at the appropriate grit level. I like Abralon for this purpose. To achieve your "dull" look, you might want to use 1000 or even 500. I like a silky sheen and go up to 4000. I do use Krylon for some things, and it sands well, and even shines up nicely, but you have to apply at least 3-4 coats. That one coat of Krylon will sand through or off very quickly, so I actually think you'd be better off without it. IMO, the oil finish will stand on its own.
Mark Wollschlager
Used a white scotch brite pad and leveled things.
Because it was labeled a latex I was not sure what could be done post application.
The Krylon web site did not give any info except for prep and drying times.
Thanks.
