bandsaw tires
bandsaw tires
bandsaw tires
Arthur A Demers
I was cutting a bowl blank and the rubber tire came off the allumium wheel ? should I glue it on and if so what kind of glue?
Re: bandsaw tires
3M 1300
Re: bandsaw tires
Re: bandsaw tires
Some bandsaw tires should be glued, some don't need it. If the tire came off because it is worn and no longer tight enough it should probably be replaced. If the wheels have raised rims like those on my 18" Rikon I don't glue in the replacement even though the originals were glued. I replaced with a better quality material than what Rikon used.
Re: bandsaw tires
Re: bandsaw tires
Dick Coers
If it's that flexible that it came off, the rubber is broken down. You need replacements.
Re: bandsaw tires
Re: bandsaw tires
mikeee12345
Eclectic E6000 will bond to rubber extremely well and stays flexible.
Re: bandsaw tires
Re: bandsaw tires
Arthur A Demers
You guy's are great thank you..
