Jet 1642 lathe
Jet 1642 lathe
Jet 1642 lathe
ben d.
Looking at a jet 1642 lathe and on the motor it says 3 phase. Does this mean it has to have 3 phase current or is it saying that 220 volt in, single phase is changed to 3 phase my means of the vfd convertor.
Re: Jet 1642 lathe
Re: Jet 1642 lathe
No it's single phase 110 or 220 in. Probably 220 on that size motor. The Variable Frequency drive on the headstock changes the 220 single phase to 3 phase and gives you the variable speed and reverse to boot.
Re: Jet 1642 lathe
Re: Jet 1642 lathe
William Duffield
If it is model JWL-1642EVS, then it is wired for 110 volts single phase.
If it is model JWL-1642EVS-2, then it is wired for 220 volts single phase.
Re: Jet 1642 lathe
Re: Jet 1642 lathe
ben d.
Thanks for the reply's that is what I wanted to know.
ben d.
