Veritas - Innovation in Tools
Drilling brass (and some amazing videos)
When making a brass handle adapter, I described some problems I had drilling brass, somewhere in this thread. Much of it probably had to do with the brass being work hardened. (long message near the end of this thread):
http://www.woodcentral.com/woodworking/forum/turning.pl/md/read/id/499266/sbj/new-roughing-gouge-handle/
However, in watching some amazing Clickspring videos about making a clock I was reminded of the value of using a zero rake on drill bits for brass. Here he tells how to modify a drill bit for brass:
https://www.youtube.com/watch?v=pAngKHIZgyA
For anyone interested in some incredible machining and even some turning brass and steel by hand, the Clickspring series is well done and captivating. He every part in the clock including the gears (wheels), pinions, hardened screws, etc. The first couple of videos:
https://www.youtube.com/watch?v=B8Y146v8HxE
https://www.youtube.com/watch?v=DoDkoioiR6w
This one has some hand-turning brass using HSS gravers, at 7:45
https://www.youtube.com/watch?v=qOHSTxxAjFs
and some hardened steel in this one, starting at 3:22
https://www.youtube.com/watch?v=Yt20qj1DHpc
He also has videos on making a variety of tools. These are inspiring if you have a small lathe/mill and like to make tools. If you don't have these, don't watch these videos or you might "need" to get them!
His web site.
http://www.clickspringprojects.com/
Re: Drilling brass (and some amazing videos)
mikeee12345
Excellent Videos!
A lot of good tips for anyone working metal parts.
Great website
Clifton C
John, I'm trying not to buy a small metal lathe...You're making it awfully difficult :)
Great info and incredible website...
Way cool. I obviously have a very long way to go in my machining skills. I guess I'm more of a carpenter in terms of machining than a fine furniture worker. Plus or minus .020" is close enough isn't it. :)
A long way to go
If you are a carpenter, I must be more of a logger with a chain saw. After watching up through videos #14 and #15 I'm in shock, nearly speechless.
It even gets better
In video #19 he machines brass wood screws. He shows using standard carbide router bits made for wood to machine curved profiles in brass. Makes sense.
Even does a little wood working on the milling machine to make a base from Australian burl and has a separate video on french polishing. All finishes are flawless, brass, steel, wood.
Re: It even gets better
Clifton C
I know I shouldn't ask this, but, I have a friend who has been thinking of buying a small metal lathe... any thoughts on books to read to help me, I mean him, get started?
cc
This might help. I started with one of the chinese mini's.
http://www.mini-lathe.com/
This guy is great to talk to.
http://www.littlemachineshop.com/
Help on which to buy, or on learning the machining?
For where to buy I asked around a lot and researched the best I could before deciding on these (about three years ago):
4841 HiTorque 8.5x20 Bench Lathe with Tooling Pkg
http://littlemachineshop.com/products/product_view.php?ProductID=4841
4288 HiTorque Mini Mill, Solid Column with Tooling Pkg
http://littlemachineshop.com/products/product_view.php?ProductID=4288
The Little Machine Shop guys are wonderful to work with. The HiTorque machines they offer are, I understand, made by the people who sell cheaper versions at Harbor Freight and elsewhere but they claim they are built to higher specs. I can believe it after looking at these, comparing with others, and talking to some people. One friend bought a cheaper version of the lathe and he said it was fine, eventually. Be he had to disassemble and clean up almost every part (with files and hones) before he was satisfied in the smoothness and precision.
Note that the cost of the machine is just a start. A rotary table, power feed, measuring instruments, granite surface plate, and a bunch of tooling later I probably have twice the cost of the machines invested! But wow, the fun!
For books on machining I'd have to check my little library for titles. There are also a great series of videos (hundreds) on YouTube by TubalCain, also MrPete222 covering everything. He's a retired teacher from when they actually taught machining in high schools.
David Walser
I've bought several items from LittleMachineShop -- all for use with my wood lathe. I've often thought he would do well to market more to woodturners. There are several items that he carries that are of use for turners. My drill chuck and my Morse Taper collets are only two examples.
mikeee12345
Machinery's Handbook is a good resource to have if you want to start machining metal.
There are plenty of editions that are available on the used market, they all have the same
basic tables and references needed for lathe and mill work. A brand new edition is expensive
but an older edition can be picked up on Ebay or other such secondary markets for a lot less.
Some of the older lathes were built rock solid and have some weight to them compared to some
of the newer import lathes on the market. The older machines are easy to work on and parts are
still available for many of them. You can find package deals with a lot of tooling on CraigsList if
you take your time and search the listings each day and wait for a good deal. A brand new lathe
will sometimes require purchasing new accessories that are made for that model. If you can find
an estate sale you can also deal on a package price for the machine and all of the tooling for one price.
mikeee12345
Joe Pieczynski is another YouTuber that has a lot of great video's on metal machining.
Dale at Metal Tips and Tricks has many great video's on YouTube.
Mrpete222 (Tubalcain) has a lot of knowledge to share on everything dealing with metal working.
Each one of these gentlemen have been machining for decades and have loads of knowledge to share.
MrPete222 has a lot of videos on rebuilding the old machines and old school tooling.
