Sanding asymmetrical handles
Skip Beardsley
A friend is making thinking of making asymmetrical handles on a production basis and is trying to figure out the sanding of them. He feels a variable speed lathe is the answer but is wondering what other solutions there are out there. Does anyone here have any suggestion on methods or machinery to do this task on a production basis.
This is potentially a full time job for one person, to give you some idea of the scope of the project.
Thanks to all for any suggestions.
Skip
Re: Sanding asymmetrical handles
John C Lucas
Go.to.Klingspor and look at their various floppy sandding discs. Probably one of these on the lathe or drill press and hand hold the handles.
A friend of mine made tool handles from the end of WWII until his death. He and his workers hand sanded tens of thousands of "striking" tool handles on belt sanders. Near the end he started to switch to patterning sanders. It worked like a copy lathe. There is a drum about 2" in diameter with a belt running around it and a steel pattern on a holder locked to the roughed out piece held like it was on the lathe. The pattern and piece rotate together and a steel finger on the sander follows the steel pattern and the drum follows the finger. Exactly like a copying lathe except the 'cutter" is sand paper.
He did not invent the machine but bought one and then improved on it. See what the handle industry is doing today.
Depends
Dick Coers
How many parts per day? How many grits needed? What size? What species? Need to be sanded with the grain after rough sanding? More information would be helpful.
Re: Depends
Skip Beardsley
It will be a full time job for one person. Several hundred pieces during the remainder on this year. Five thousand or more next year.
Thanks for your interest.
Skip
100 a week?
Dick Coers
Not sure that is full time work. On a copy lathe, you should be able to make that many in one or two days. But, still no idea what the heck he will be making and how well it needs to be sanded.
