Ying Yang mirror with cold bend wood
This was another project started this week. As the Zebra wood was drying I would make a cut or two on this project. I was using some dry cold bend wood. It needs to be wet to bend and I wasn't sure how re wetting this wood that has dried would work. turns out it works perfectly. I wet the ash and let it sit overnight. Then I clamped it in the precut mirror pieces. I let that sit for 2 days. Then I glued them together using epoxy. then turned and carved it. The handle was easier because the bend wasn't so severe so I took one of the pieces that was almost dry and glued it together with yellow glue.
Re: Ying Yang mirror with cold bend wood
Very Cool!
Wow!
Re: Wow!
William Rogers
Vert nice.
Very nice, John...
GaryG in MD
Interesting techniques. ...GG
Dennis in Southern Oregon
A very pretty result John! Is there any risk in the end grain to cross grain glue joints with temperature and RH cycling?
Sometimes. However Mahagony has about the same movement in either direction. It is a very stable wood. The Ash will not have any real movement sideways and I doubt it will change length much either since it's actually been crushed and the fibers overlap. Cold bend wood reacts differently to wood movement than other woods and I'm still new at figuring it out.
This is a mirror I will probably keep for a good while so I'll get to watch it. On woods that move much I prefer to match the grain.
Keith Tompkins
Keith Tompkins
Nice John!!
Mike Brazeau
Very nice John. Glad to hear that it can be reactivated. Have a piece that Mike Hosaluk handed out at St. Paul symposium and dried out long ago.
philip f Duffy
Great idea and execution, John! Phil
