Fidget Spinners
Fidget Spinners
Fidget Spinners
mikeee12345
Is anyone building Fidget Spinners on this site? This looks like an easy item that
can be adapted to a wood lathe project and a great project to build for gift items
that fit any age group. These items range in price from a dollar all the way up to
the high end market with collector grade items. I would compare this to the spinning
top market very diverse to say the least.
Re: Fidget Spinners
Re: Fidget Spinners
Do you know a good source for bearings?
Re: Fidget Spinners
Re: Fidget Spinners bearings
Darryl
skateboard bearings from Amazon or Boca Bearings in Florida
Re: Fidget Spinners
mikeee12345
There are a ton of fidget bearing listings on EBay, all depends on what
color and type of material you want for the final product. You can also
remove the seals from a standard sealed bearing and remove the grease
and oil with a solvent to get a "dry" bearing. The final size of your item
will somewhat determine the size of bearings you want to use.
Re: Fidget Spinners
The new pet rocks!
Re: Fidget Spinners
Re: The new pet rocks!
mikeee12345
One of those fads just like the internet. :-)
Re: Fidget Spinners
My niece is a teacher, she loathes those things!
Re: Fidget Spinners
That's exactly what I said!
Then last week a girl, 13, told me she (and her family) still plays with the little finger top I gave her as a kindergartner.
Re: Fidget Spinners
Re: My niece is a teacher, she loathes those thing
mikeee12345
Back in my school days chewing gum was a major offense. :-)
Today some teachers deal with guns, knives, and drugs on a regular basis in the class room.
Some of these teachers would be content with fidget spinners and cell phones instead of
dealing with the other extreme distractions. Self-discipline is becoming a lost skill set for many
of today's youth. Society is now paying the price.
Re: Fidget Spinners
Re: Fidget Spinners *PICS*
Ed Davidson
Yeah, I'm guilty...been making the little buggers for a few months now. Mostly give them away to the local kids (dads and moms want them too). The most popular design I make are those with a bicycle theme, using bike chain and sometimes derailleur pulleys. The paracord/skull ones are prtty cool as well. For how-to's, search YouTube: "DIY fidget spinner".
Re: Fidget Spinners
mikeee12345
Ed,
I knew there had to be someone in the group making a few of these.
I was thinking about some burl wood or a combination of woods in a circular
form with a center bearing. Seems like the best design concept is a form with
a weighted outer circumference similar to a spinning top. You still need a convenient
means of spinning the device with your finger tip, so arms or cogs extending outward
from the body provide an easy mechanical advantage for accelerating the device. The
bike derailleur or a simple toothed gear is a great idea! I need to put the metal lathe and
wood lathe to work and try to marry the two materials into a functional item.
Re: Fidget Spinners
Ed Davidson
Here's some pointers on making spinners, based in my experience:
- Almost all bearings will come out of the box with grease or oil in the races, which is a speed and spin-time killer. Bearings run best if they are clean and completely dry...no lube. However, most cheap bearings are steel (not stainless), and will rust.
- Start with a skateboard size "608" bearing that is stainless steel (both balls and races). They'll run between about $1.00 and $8.00 each through eBay or Amazon, depending on if you get them from a Chinese or domestic seller. Direct from China is much cheaper, but will take 4 to 8 weeks to deliver.
- Another alternative is a full-ceramic (all white) bearing, but they will cost between $8.00 and $15.00 each, no matter where you get them.
- The best bearing solution I've found is a "608" design with ceramic (white, sometimes black) balls and stainless races and body. They are available on Amazon.com in packs of 8 for around $27. Search for: Amphetamine Ceramic Skateboard Bearings
- If you use full ceramic (white) bearings, note that the body is made from Delrin or Nylon, and will flex. If you squeeze (press-fit) the bearing body into a tight hole, expect spin time to go way down.
- Most bearings will come with a plastic or metal shield on each side that protects the balls/races from contamination. You'll have to remove (maybe destroy) those shields to clean the bearings.
- Clean bearings with any de-greaser...citrus based works best. Rubbing alcohol or acetate works equally well if you don't mind handling flammables. Dry the bearings with high pressure compressed air.
- Yes, you definitely need some weight around the outer rim...to help with spin times/speed and general momentum.
- Note that almost all spinners have some kind of cap that your thumb and finger rest on that is proud of the bearing races...so your hand doesn't touch (slow down) the spinner. The caps also help keep dirt out of the races. All caps are two-parts, press fix or threaded through the bearing hole. They can be purchased online from people who do CNC machining, plastic injection molding and 3D printing. Search for fidget spinner "buttons" or "caps"
Re: Fidget Spinners
mikeee12345
Ed,
What I was pondering was a Fidget Spinner with (1) central bearing with (2) oversized
caps turned on the lathe with the center gear teeth exposed on the outer rim between the caps.
The (2) outer caps would be turned from wood or composite materials to provide a decorative
element to the device. There are so many different concepts possible for this device.
Re: Fidget Spinners
Re: Fidget Spinners *PICS* *LINK*
Ed Davidson
Good luck...post pictures of whatever you come up.
In the mean time, have a look at this one...the latest version of a high-end, super expensive and limited edition spinner. Should be sold out within an hour of it's launch tonight:
SpinnerMint blog
Re: Fidget Spinners
mikeee12345
All I need is a $400,000 CNC lathe and I can start producing in quantity. :-)
Re: Fidget Spinners
I read that a lot of people are making these on 3D printers using free downloaded files.
Re: Fidget Spinners
Thanks for the details, Ed. Just this weekend I was asked if I could make a couple from wood.
