Another 5/8" shaft capacity handle
Yesterday I made another 5/8" handle adapter for the second Thompson roughing gouge. I made this one from 6061 aluminum instead of the hard-to-machine unknown brass - MUCH easier! It took only a fraction of the time. I figured out how to hold my boring bars on the metal lathe which helped too. BTW, the set screws are 5/16" 18 tpi, ground significantly to make them short enough.
The handle is Bubinga with some Dremel stippling for texture.
This handle is smaller but feels about right.
Here are both the new 5/8" capacity handles with the 5/8" and 1" roughing gouges. I think that's enough for now! Finish on both is one application of danish oil, wiped dry after about 15 minutes, then lightly buffed.
After making a bunch of these handle adapters with set screws, I don't think I'll ever make another handle with the tool glued in. It is so handy to swap tools and remove them for sharpening and I can store a bunch of tools without handles in some shallow drawers.
BTW, someone asked me why I waste time making "fancy" handles. The short answer is I like to experiment with different techniques with no great loss if they don't work out. For the Bubinga handle I tried carving a larger than "usual" stippled area then sanded with 600 grit which added some flat areas. I think that has some promise with a little different carved pattern.
