Nova DVR Upgrade panel and sudden starts
John in Lutz
Nova is selling a Control Panel Upgrade (part #55523) for the Nova DVRs version 6.06 and newer. It has many nice features including 10 presets that can be accessed with one finger instead of combination of two fingers required by my old panel. It also includes a knob for speed adjustment. It is only $150, so in the lathe world is a good deal.
I had one problem with mine. By the second or third day when I using the lathe it start up by itself. Fortunately I was working a small spindle so not a problem but definitely a surprise. I reset things and seemed fine until the next day when it did it again. I put my old panel on and called Novausa. The gentleman I spoke with was very good and ultimately suggested I put the ferrite choke that came in the kit on the ribbon wire attaching the panel to the lathe.
While the kit included the ferrite choke the manual included did not tell how it was to be installed. I believe I read somewhere amongst some of the nova on-line documentation on line that it is used if you adding the remote control which I did not. The nova rep told me you do this by twisting the ribbon cable as the hole in the choke was much narrower than the ribbon. That worked well. Since I installed the choke (two weeks ago) I have had no problems and really like the panel. I did get a follow communication that Nova was updating the instruction and that would be included in the next version. For those who might be using the new panel before the updated instructions come out, I hope this is helpful.
This is the link to the instructions for the upgrade panel. (maybe the longest in history)
s3.amazonaws.com/cdn.freshdesk.com/data/helpdesk/attachments/production/19003628721/original/SKU%2055523%20DVR%20XP%20Control%20Panel%20Upgrade%20%20Manual%2006.12.2016.pdf?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAJ2JSYZ7O3I4JO6DA%2F20170422%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20170422T230851Z&X-Amz-Expires=300&X-Amz-Signature=447b710f028f0a545091c23af5176a0b6faced2d7e891949409a69f48b0b9852&X-Amz-SignedHeaders=Host&response-content-type=application%2Fpdf
Re: Nova DVR Upgrade panel and sudden starts
Ron Pemberton
Installing the upgrade, did you have trouble removing the pulley? Are you pleased with the upgrade and would recommend it.
John in Lutz
The panel is held in place by four screws, two on each side. You do not have to remove them, just loosen and side the panel off. Then you unplug the ribbon cable.
To install wrap the ferrite choke around the ribbon cable and plug it in to the new panel. Then slide the panel in place and tighten the screws.
Nothing else has to be removed or taken a part.
Unfortunately...
Ralph Lindberg
My DVR-XP is running ver 4
So I would need a new mother board also $$$$
Besides getting to the mother board is a large pain
(despite the fact my DVR-XP has a over 1000 times the hours, I've had to fix the clubs DVR twice, and mine not once)
Bill Blasic
Re: Unfortunately...
Bill Blasic
I am lucky as I had upgraded my board on my DVR 3000 and it had version 6.02. I did a review of the upgrade panel for More Woodturning Magazine and I am thrilled that the upgrade gives to those capable of using it a speed knob that most owners will really enjoy plus a lot of new options.
That's the reason I went with the Powermatic
I have owned a Nova Comet and a 16" Nova. I loved both machines. When I was looking at upgrading again I looked very closely at the New Nova with all the electronics. What worried me was the motor and electronics being so specialized. I was looking at long term. I've seen a lot of lathe companies go under or drop certain models and parts replacement along with those. I was worried about problems with the motor or controller and then not being able to get parts. Nova is an excellent company with a wonderful reputation but still, things happen.
there were 2 other companies out of Europe that marketed lathes with technology similar to Nova. What happened to them? What has happened to those lathes that were sold. That's what worried me.
I went with Powermatic because I planned on having that machine for a very long time. There isn't anything on that machine that I can't replace either by a good machinist or with aftermarket motor or controller. After 15 or 20 years we are starting to see some failures of the Powermatic controller and people have been able to replace it with an aftermarket controller. Bearings and even the motor itself are easily replaceable with off the shelf parts.
Alan Zenreich
Alan Zenreich
I upgraded the panel on my DVR XP a couple of weeks ago, and installed the ferrite core at that point. I have not experienced anything unexpected. I REALLY like the 10 preset speeds, and how easy they are to set via button presses.
Re: Nova DVR Upgrade panel and sudden starts *LINK*
Dave Paine
Alan, how old is your DVR XP?
Mine is 2011 and has 6.xx software version which Teknatool state is compatible except for the braking function.
It is tempting to be able to get the knob for speed change. I looked at the Galaxi at the local Woodcraft store. I am not sure I like the way the 10 presets work, but I expect I would not want so many presets.
http://www.novatoolsusa.com/NOVA-DVR-XP-Upgrade-Panel-Kit-55523.htm
Alan Zenreich
Alan Zenreich
Dave,
My XP also has 6.x software.
The 10 presets are very easy... 5 buttons, either a single press for the first 5 presets or a double press for the 6-10 presets... then press P to confirm.
Of course, you can also use the dial to increase or decrease the speeds, but with my presets at 250 rpm intervals, that means I don't need to twiddle the dial much, if at all.
Also, realize that you can change any of the presets to be whatever RPM you want... so you can use as many or as few buttons as you like for your needs.
Re: Thanks for the detail
