A little playing-more mirrors
I got some of the JoSanjo irridescent paints and have been learning how to use them. A lot of fun. You mix in some Flow extender, about 50/50 or even more diluted. Then you spread some on the piece. The Flow extender extends the drying time considerably so you have lots of time to manipulate it. I used a straw on the multicolored piece and my air brush with just the air on the gold and green piece. On the Gold and green one I forgot to give it some tooth by rubbing it with green scotch brite. That's what I do before airbrushing so the paints will stick well. With the JoSanjo paints I got some little bubbles which in this case didn't hurt anything but i need to remember if I want a smooth flow of the paint I need to rub it down first.
The bottom mirrors is the other half of the burl piece I posted a week or so ago.
Re: A little playing-more mirrors
Impressive!
171 views and 1 response
I find that interesting. I'm not looking for atta boys. I guess I should post comments and critics welcome. One reason I publish my work is to try and get conversations going about techniques, design, tool usage, etc. By doing this I hope we can all learn something. I don't have a bit of problem with someone saying, I'm not so sure about that design, or perhaps you can try this. I'm open to all sorts of experimenting and will gladly discuss the techniques I use. I think I mentioned it but I learned about this technique using the flow extender from 2 other turners, who in turn learned it from someone else. The free flow of instruction is a lot of what turning is all about.
I'll be typing using my phone for the next 6 weeks except on weekends so please excuse the typos. I probably won't have much turning to display during this period either. I'll only be home on weekends and will have to get caught up on chores around the house before I can play.
George Balock
Re: 171 views and 1 response
George Balock
John,
I think they are gorgeous. So, how are they finished? It looks like dyed or painted wood, then iridescent pant, then oil or spray?
George
John C Lucas
Im still experimenting. I used spray paint for the black under coat. That didnt work well. I tried using minwax wipe on poly as my final coat and it tended to smear the black. I then tried Krylon Fixatif that ive used o er a lot of other paints. It didnt bond well to the black and tried to rub off when i used the Beale Buff. I have switched to Trans Tint dyes or shoe dye both of which work a lot better but require 2 or 3 coats to get the necessary deep black. The JoSanjo paints are water based so im starti g my search for a really glossy finish that will be compatible and not look like thick plastic. Id like to.use.the commercial lacquer that ive.used for years but i still dont have my compressor hooked up. Its gonna take about $200 and a. Ouple of days to run all the connections and right now just dont have either
