ADVERTISE HERE - FREE TRIAL
I Missed the Derek Weidman Demo!
Charlie belden
I can't believe I missed his demo. As one who has been studying multi axis turning (thanks to Barbara Dill), what Derek does with multi axis turning, or HOW he does what he does, has me baffled - in part because to understand how a MA piece is done from just photos you need as many views as there are axes PLUS a few more.
But - I got to see and hold the piece he did for the demo -though not long enough to study it. Am hoping I can borrow the piece, study it - and create virtual 3d models of the steps used to turn the piece.
Will report back if I pull this off - and make the step by step SketchUp models available on my web site. This should be interesting . . .
Re: I Missed the Derek Weidman Demo!
Peter Hyde
Charlie you are making it too complicated😄
The way Derek works is by visualization and checking the new axis is not going to remove wood from the wrong places. I successfully did a couple of Weidman like pieces earlier this year and once you get your head around a few basic principles you can really make progress
Peter Hyde
Here's what I managed to do. A bit crude but as you can see I managed to achieve reasonable results just by simply having a drawing of what I wanted to do and then moving the blank around between centres to find out where wood was going to be removed. Use a cup centre to drive so that the piece stops if you get a catch. A steb centre doesn't work too well.
Cup center
Dick Coers
I watched Derek do a demo at SOFA. If he tightened the tail stock once, he tightened it a hundred times. It got to the point of distraction! I'd suggest a Steb center instead. In reference to learning and developing a technique, I'm not sure anyone can figure out enough parameters on paper (or work out exact designs) to ever figure out what is in Derek's head! That guy is in his own world!
Re: Cup center
Peter Hyde
Because of the extreme off centre a catch would cause the stebcentre to act as a drill bit and leave a really deep mark on the wood. Derek uses a cup centre for a drive because it relies just on friction to grip, hence the constant tightening. I didn't find I needed to tighten as much as he does, just immediately after a catch.
You get used to the catch problem pretty quickly and it can be used to check progress without stopping the lathe. Puts some wear on your belt but it allows you to do a very quick visual check on your progress. I also found there's a natural speed to make decent cuts and catches were mainly caused when the rpm was too low.
Lots of things to learn doing this sort of carving, bevel rubbing is almost impossible and you get used to big tool overhangs pretty quickly so big bowl gouge is necessary.
Watching Derek work is like ..........
JamieDonaldson
....watching a magician create tricks, but with a running commentary!
