REAL MILK PAINT
Carba-tec Threadmaster
mikeee12345
Does anyone on this site have a Carba-tec Threadmaster threading machine?
I am trying to verify what threads are used on the main housing for the spindle bushings.
This particular machine had different bushing adapters for several different thread sizes.
This machine was made in Australia so I am thinking the threads may be metric for the housing.
They made American threaded spindles for the US market and I would assume metric spindles
for the international market.
I was hoping if someone has a manual it might detail what size these threads are.
I am also looking for bushings or spindles for this machine if anyone has any spares.
I am looking at a used machine that is missing the bushings and spindles.
Re: Carba-tec Threadmaster
mikeee12345
This may help someone down the road.
I ended up with the Carba-tec threading jig less spindle and bushings.
I used a metric thread pitch gauge and verified the spindle throat has M30-2 threads.
I ordered an M30-2 die and started turning several bushings to complete the jig.
I am using a metal lathe to machine the bushings to size and will use a tap & die
to cut the inner and outer threads.
The locking post has an M8-1.25 metric thread which needs to be extended if used
on any lathe other then the old Carba-tec lathe.
There are 4 threaded mounting holes in the base of the threading jig these are metric M6 threads.
The threaded mounting holes makes it easy to mount the jig to a raised base for the lathe you have.
Ken Vaughan
Ken Vaughan
3/4 by 16 and 3/4 by 10 are good threads for the inside of the bushings.
They are easy to get as all thread rod, and fittings to chuck/faceplate threads are readily available (if not already in hand).
X-Y vise is a good adjustable mounting base
This jig does not need to be precise on centerline. Close or even sloppy close works fine.
mikeee12345
If I have time I might turn several different sized bushings for different sized spindles.
I have a 1x8 spindle on several of my lathes and bowl chucks so I might try to see if I can
make that size of bushing first, or make a bushing adapter to fit my bowl chuck for a 3/4"
spindle.
mikeee12345
I have 1x8 threads on several lathes and several bowl chucks, I might make several
different sizes if I get time to get them turned on the metal lathe. It will be nice having a
threading jig to cut threads into wood, at last.
mikeee12345
I was sizing the threads for the hand turning wheel today and it looks
like it is threaded for an M16-1.5 metric thread. This is the large hand wheel
on the tail stock side that you use to turn the billet and advance the piece towards
the thread cutter.
mikeee12345
After turning a set of bushings and checking the thread fit on the Carba-tec body,
it turns out the thread is actually M31-2 that is needed for the spindle bushings.
