A few tricks you may not have seen
I was turning a new mirror which had some challenges and required a few techniques you may not have seen before so here they are. First of all this was part of a burl cap that I was given. It was just a slice off the end and the one who gave it didn't know what to do with it. It was thin, about 2" at the deepest part and about 10" across tapering out to quite thin. I cut 2 mirror blanks our of it and then some mirror handles. One of the mirror blanks was fairly thick so I decided to slide the burl top off of it so I just had the nice curly wood. I hate to throw anything away so I looked at this burl top and decided to make a mirror out of it. It was too thin and needed some wood added to it. I mounted it in my homemade chuck that I use occasionally to hold mirrors with odd shaped tops. By carefully tapping the mirror to get the more or less flat side as close to true as possible I tightened the chuck and faced it off flat.
Now I took some of the scrap pieces of burl and cut it into 1/2" stips that were maybe 3 to 5" long. I was able to put those on my seg easy sled and managed to get 12 segments just long enough to make a ring to fit on the mirror and make it thick enough to be useful. Glued that to the mirror that was still in the homemade chuck and turned the ring round and made a recess for the mirror glass. Then turned took it out of that chuck and put it on my 4" chuck to finish rounding the outside of the mirror.
Now came the handle. I only had an odd shaped piece of scrap left and decided it would make a curved handle. I wanted the first couple of inches to be turned to kind of match the turned outside of the burl. I cut a notch in a waste area and mounted my small drive center in a #2 morse taper extension. You can buy those at most metal supply houses pretty inexpensively. I find them indespensible for some operations on the lathe, both in the tailstock and the headstock. I started it between a cup center but as I turned it this wood was too small on the tailstock end to use a cup center. I changed to a cone center. If you use a cone center you will split the wood. So I put a tiny washer on the cone center so it can only go so deep. I predrilled the spindle to keep from splitting even with the small cone that extended. This allowed me to turn those first couple of inches. I carved the rest of the handle.
Re: A few tricks you may not have seen
a treasure trove of tips!
GaryG in MD
Great stuff, John; thanks. ...GG
Don Evans
Very nice John.
I use to make mirror's years ago but didn't ever try burl like that, one reason was I never had access to it as we do now days. Things have really changed in that department.
I came up with a different way of attaching handles that I liked, which allowed me to not put the handle itself into the main body as you do. I turned a scrap piece the same diameter as the mirror body and wrapped sandpaper around the outside of it. With it still in the lathe I could then put sandpaper strip around the outside of it and hold a small block against it to sand the shape on one edge of the block. Then mount the block to the mirror base predrilled to take the end of the handle, I also put a small dowell in the block to the mirror base glued in.
This made a perfect fit and I would then hand carve the block to correct thickness and shape I wanted.
Feel free to try it this way sometime.
Don
Don I've mounted handles a lot of ways over the years. Some of my earliest ones were quite thin so I mounted the handles to them a couple of ways. ONe was to simply make the handle longer so it ran up onto the mirror body. I then shaped it to match the mirror curve and put brass pins through it to hold it on.
Another way was to make a sort of T. 3/8" on the bottom and about an inch on the top. The top part was about 1/2" thick. I would then drill into the side of this and sometimes into the mirror body it'self and glue the handle into that.
Then I"ve done somewhat what you describe. I make the handle wide where it touches the mirror. shape it to match the outside of the mirror and then either pin it, or in some cases I did a mortise and tenon.
the way I do it now is much faster and easier and still looks fine.
Very clever! I especially like the tiny washer on the cone to prevent splitting.
I could have used that a couple of weeks ago. I was teaching some kids to make oven sticks and the only centers they had were cone centers. One boy kept tightening his until his wood split.
Alan Zenreich
Alan Zenreich
Very nicely done, John.
WOW!  Stunning!!!
ebd
Beautiful. Great save of very special wood!!!
