Cleaning up after hollowing
I was making some Beads of Courage boxes. I still hollow this kind mostly with a bowl gouge because I'm just better with it. I hollowed under the lip with a bent tool similar to John Jordan's with a 3/16" HSS cutter. To clean everything up I use 2 Hunter tools. A #5 which I think he is calling a Badger now. This is a straight tool and lets me cut the bottom and part of the sides with a bevel rubbing cut that is extremely clean.
Then I used what he calls a Badger #5 swan neck to clean up the upper sides and under the lip. This tool will do a bevel rubbing cut up the sides and up part of the undercut. Then it turns into a shear scraping cut to get out toward the lip. Both are very clean cuts.
Here are a couple of photos showing the cuts before any sanding. It's hard to really see how clean they are because you can't get the light in there.
