The hardest wood I've ever tried to turn
David Walser
Today, I was trying to finish a bocote pendant I'm making for my wife's birthday. From the rest of the blank, I turned some beads to access the pendant. At least, I tried to turn some beads. The blank was only 5/8ths" square by 2" long, but none of my tools would cut it. This was some hard bocote! My roughing gouge wouldn't cut it. My bedan couldn't make a peeling cut. I tried a bowl gouge, a 3/8" spindle gouge, and, in desperation, a negative rake scraper. All to no real effect. The corners of the blank barely showed any progress. It was as if I'd been using 80 grit sandpaper instead of very sharp turning tools!
In desperation, I started looking for my carbide scrapers when I noticed that I'd left the lathe in reverse after sanding the pendant. Five minutes later, I had some very nice beads ready for sanding.
