A55 Smoothing Plane
Big clock done
Big clock done
Big clock done
Finally got it done. At least I hope the client is happy. Mounting the door in the upper bonnet was a nightmare. They had jury rigged the mounting somewhere years ago. I filled in all screw holes and redrilled them. However the cabinet had warped or shifted just a tiny bit. The door barely fit. The brass washers that support the door were the wrong size. I turned them down to the correct size on my metal lathe. I got the bottom hole perfect but the top hole was off a hair and had to be re filled and then redrilled. I had to drill the holes with a right angle attachment on my dremel which made it hard to drill them accurately. I could see where they had planed part of the door to make it fit earlier. I planed it just a hair and sanded one area on the top and now it fits like a glove.
Re: Big clock done
Re: Big clock done
Mike Brazeau
You are simply amazing John. Great work.
Re: Big clock done
Re: Big clock done
Dave Delo
Agreed..............
Re: Big clock done
Jim Barbour
Re: Big clock done
Jim Barbour
glorious work John
Re: Big clock done
Re: Big clock done
Excellent! Seems like that was a huge amount of tedious work.
Hey, this could be a new career! Forget all that silly woodturning. I'll bet you are advertising on Craigslist right now looking for more old clock work. :-)
Re: Big clock done
Re: Big clock done
John Stegall
Great clockwork. I have been meaning to ask, Which metal lathe do you have?
John
Re: Big clock done
Keith Tompkins
Re: Big clock done
Keith tompkins
Well done John!!!
Re: Big clock done
Re: Big clock done
John C Lucas
I found a good deal on a use Smithy years ago. It was poorly aligned when I got it and not being a machinist it's taken a while to get it up to the kind of accuracy I would like to have. Still ive had a lot of fun and made a lot of simple stuff .
