Why do they still make spindle gouges?
cameron
Been doing a bunch of research on turning since I got my lathe a few months back (hence the litany of questionable posts...) and have run across unanamous decrees on the non-suitability of a spindle gouge for bowl turning but with the counter point that a bowl gouge can be used for both bowls and spindles. I have to ask, this being the case, why are they even still making spindle gouges? The only thing I can come up with is that they are probably a little cheaper to make and are a little smaller so they can get at finer detail in some cases. Both of those points seem pretty weak, however, considering economies of scale should eliminate metal content if manufacturers could simplify their catalog and they make smaller bowl gouges, throw on an Irish grind and you've got the ability to get into a pretty small space... Am I missing something? This also makes me wonder why they make the roughing gouge for the same reasons, if they are weak and you can do the job as well or better with a bowl gouge...
Just some of the million thoughts that keep me from a good night's sleep.
Most of this finial was done with a 3/8" spindle gouge, the details with a skew. Pretty tough to do with a bowl gouge.
