Working on a new article
John C Lucas
I'm working on a new article on turning Tagua nuts. My wife says maybe you won't hurt your thumb taking photos. If she wasn't the boss I would have called her a smat elick. You can get I'm going to be more careful today. You don't think about turning small objects to be dangerous but when your work I g with a 2 up machine it could have ripped my thumb right off.
Re: Working on a new article
Normally type with your thumbs?
Dick Coers
A few errors in that message with your thumb wrapped up! :D
Re: Normally type with your thumbs?
I could claim it was my injury but in reality I have small hands and big fingers which makes it impossible to type on my phone. One of these days I'll get a laptop or something to use in the shop besides my phone.
Brad Vietje
Brad Vietje
I use a friction drive for an extra measure of safety. I do get pretty over-confident, though, and crank up the tension for more aggressive cutting, so I'm not sure it would have helped you if you had done the same. For spindle work held between centers, a light touch and a friction drive can help; that's just not how I always use it.
I look forward to the article.
Safe spinning,
Brad Vietje
Newbury, VT
What's your favorite tool now? Thumbnail scraper
John C Lucas
This piece was in a Chuck so it wasn't going to give. I guess I turn too avressi Ely because friction drives simply don't work for me.
lathe clutch
I always wondered if lathes should have an adjustable clutch built in like on my bushhog, set low or high as needed. Would work like a safety drive except with chucks and faceplates too.
Re: lathe clutch
I could have used a lathe clutch when I was turning a very large piece many years ago. I turned the lathe on and then back off when it reached the speed I found acceptable. I rigged up a foot switch so I could turn it off then back on and kind or roughly maintained that speed. It would have been much easier if I could have simply slipped a clutch a little. That was on a Reeves drive with a slow speed of 600, way to fast for that project.
loosen the belt
Dick Coers
Who promoted that decades ago? A foot operated lever that took the weight of the motor off the drive belt. Slip the belt to handle difficulties or a quick way to inspect your work. Was that Del Stubbs? I sure can't recall.
Jim Barbour
Re: loosen the belt
Jim Barbour
I believe it was Del Stubbs with the foot lever and that he has that in his bowl video.
Brad Vietje
Del Stubbs For Sure
Brad Vietje
Del was showing how he'd modified an old General (260?) with a tension pedal on the lower pulley.
I almost never add any extra tension to the drive belt; if it needs to slip, I WANT it to slip. When working on hollow forms with quite a small opening, I sure don't want the lathe trying to remove my arm if something went terribly wrong. I've never had any incident when the slippage was called for, and hope I never do, but you never know.
Coring bowls is probably the only time I push down on the 3520 motor to add tension.
Safe spinning,
Brad Vietje
Newbury, VT
Re: lathe clutch
David Walser
Del Stubb's lathe clutch (IIRC) was a leg switch that lifted the motor, allowing the drive belt to slip. You operated it by using your thigh to press against a bar that ran the below the bed the full length of the lathe. I believe Del covered the bar with a wide piece of plywood -- making it easier to hit in an emergency.
It's a neat idea and is pretty simple to rig up for lathes with the motor slung low under the headstock. For lathes like the PM 3520b, which have the motor attached to the headstock AND have a sliding headstock, it's not so simple. I think for most modern lathes, a bar the runs under the lathe bed that operates a kill switch would be a better option.
