Thoughts about rotary carving and burrs
Dave Belser
I'm working on a new concept / process and it requires what I would call trenching or routing turned surfaces to a depth of about a 1/4 inch. I've got a flex-shaft rotary tool that I'd like to use. It seems to do the trick, but I need to find the right burrs.
I've got a very small selection of solid carbide burrs that I was playing with and they do the trick but it will be a slow job if I stick with just them. The burr shapes that seem to work best are round/ball for most of the material removal and then a cylinder tip to make the walls straight. The ones that work best are the single cut (not diamond fluted) they are more aggressive.
I'm about to buy a better selection of sizes that would help (bigger ones can be used for roughing). I've used "saber tooth" burrs for other work, all the ones I've seen are way to big for this kind of work.
It does occur to me that a small spiral-upcut router bit might work better and faster. I'd need 1/8 & 1/6 for the size I'm working at. I don't know if these exist or if they would be manageable (safe!) in a handheld rotary carver.
Another obvious approach would be to setup a small router on a sled and do this with the work mounted on the lath. I've got two issues with this approach, I'd loose some of the "freehand" aspect - it would be much harder to see what I'm trying to accomplish. And second, I don't have the router for this and I'm pretty broke right now.
So - I'm primarily looking for thoughts on what burrs/tips would work and where to find them.
- Dave
