Galaxy mirror 2
Galaxy mirror 2
Galaxy mirror 2
This is the second in the Galaxy mirror attempts. I'm getting better with the air brush but sure do need a lot of practice. I also used a dovetail bit in the router instead of the 1/2" straight bit. I like the sharper angle for this type of cut in the mirror.
Re: Galaxy mirror 2
Re: Galaxy mirror 2
Roger Chandler
That is a fine piece of work, John.......especially the router setup to make the design.....really cool!
Re: Galaxy mirror 2
Re: Galaxy mirror 2
mikeee12345
John,
When mounting the turned piece offset in the chuck, how are you attaching the wood piece?
Very nice looking piece!
Re: Galaxy mirror 2
Out of This World!
Re: Galaxy mirror 2
Very impressive, John
Re: Galaxy mirror 2
Re: Galaxy mirror 2
I just use a 1" square block and CA glue it to the inside of the mirror. Sometimes as in this case I had to round over one side so it was more like 1" x 3/4". I hold it with my chuck. Sometimes I will use a rectangular piece of wood and remove 2 jaws from the chuck so I can more easily position the piece where I want it.
Re: Galaxy mirror 2
Re: Galaxy mirror 2
mikeee12345
Thank You,
That sounds too simple and easy of a solution, it needs to be a complex jig or $500.00 off center
chuck attachment holding device. :-)
