More square ornaments.
I tried a few new ones. The silver one is a new experiment. I reduced the size of the bowls and made them deeper so I still had the holes all the way around but now I had room to do some texturing. Used the chinese knockoff of the small Sorby texturing tool.
I also included a group photo of all of the square ornaments.
Re: More square ornaments.
What incredible creativity. You are a turning madman, out of control! I can't wait to see what you come up with next. :-)
Ed Davidson
Big thumbs-up for uniqueness and beauty...well done.
Roger Chandler
Those are just plain cool, John. Looks like they might be fun to make.
David Walser
John -- These are fantastic! How did you do the two that do not have holes in the middle?
I assume you are talking about the white one and the gold one that I did with the router. I use a router table that mounts on my banjo or one that sits on the ways of the lathe. then I use one of my index wheels to align the router. I have the router mounted on a cradle that holds the small router at a 45 degree angle. Then I use a 1/2" straight bit and cut with just the corner. I align the table at an angle so it will take a deep cut at the beginning and run out of the cut toward the middle. In the gold one I had the router mounted below center. This makes the cuts look like they spiral.
If that's not clear enough I can dig up some photos of my set up.
you have an amazing imagination, John!
GaryG in MD
Very well done! ...GG
Re: you have an amazing imagination, John!
mikeee12345
Very Nice! That takes thinking inside the box to the next level. :-)
