latest work
latest work
latest work
GaryG in MD
I rarely get to turn any more because I have to turn outside, and "life" and "weather" tend to get in the way. Anyway, I had a nice day recently and managed to get the finial turned for this HF. The HF was an exercise in hollowing the shoulder of a flat-top form. The finial is straight from the cover of American Woodturner Vol.29 #1 (Feb. 2014). 7-1/8" high and 5" diameter -- pretty much Golden Ratio. The HF is Bradford pear, with a little cambium left on one side for decoration, finished with rattlecan shellac rubbed out to 4k with Abralon, and the finial is "canarywood" (an exotic) finished with a couple coats of Behlen's 100% pure tung oil, rubbed out to Abralon 4k.
C&C welcome and encouraged. Yes, I know the finial dominates the HF. The plan was for what I hoped would be a good balance of the whole. In real life, in three dimensions, I think the balance is better than in this 2D view. It's in the eye of the beholder -- you tell me. ...GG
Re: latest work
Re: latest work
You did a good job. The finial is excellent with very clean lines. Yes it's probably a little large but not that bad. It sort of becomes about the finial instead of being about the hollow form.
Re: latest work
Re: Canarywood? *LINK*
William Duffield
Centrolobium would not have been my first guess for the finial species.
Beautifully executed!
Wood Database - Canarywood
Re: latest work
Dennis in Southern Oregon
Re: latest work
Very nice Gary. I like the crisp detail you achieved on the finial.
Re: latest work
Re: Canarywood?
GaryG in MD
I know what you mean, and have to agree, but the linked page says the heartwood can be a darker reddish brown. Most of the canarywood I have (from a trusted seller) is lighter and more variegated. We're pretty much at the mercy of the sellers re ID when we buy this stuff. I've had this piece sitting around for about ten years. I just checked to see where I got it, and it's not from a seller I've had any more experience with, or can say I trust. So it's a pig in a poke. It actually looks a lot like padauk, which is kind of scary in afterthought, because I'm very allergic to padauk! But I didn't have a reaction, so it's not that. ...GG
Re: latest work
thanks, John
GaryG in MD
Agreed.
In real life, seen in 3D and not yypically directly from the side, it actually appears more balanced, and I'm happy with it. ...GG
Re: latest work
Thanks, Dennis
GaryG in MD
I did the best I could off the tool and minimized sanding.
I only had one skew spiral, and that was at an early enough stage that it was easily removed. I need a lot more practice with that tool, but I'm a lot more comfortable with a low-angle detail gouge (a skew with the ends curved up!), so I tend to use it most of the time for this kind of thing. ...GG
Re: latest work
Brad Vietje
Re: latest work
Brad Vietje
Very nice work. Doubtful of the Canarywood -- looks like some Redheart I turned a while back.
Safe spinning,
Brad Vietje
Newbury, VT
Re: latest work
thanks, Brad
GaryG in MD
It's a lot more ring porous than redheart -- I just compared it to some RH pen pen blanks I have here.
I'll be honest -- it looks a lot like padauk, which scares the crap out of me now in retrospect, because I had a very bad allergic reaction to some wood that was sold to me as padauk, and this, thankfully, didn't give me a problem. So now, the question is whether the other stuff was really padauk. It was variegated and very unusual, which is why I bought it in the first place, but otherwise did, indeed, seem to be padauk. When I turned a French rolling pin for my daughter out of it, I got a bad rash. So now I don't know what to think.
Re: latest work
That looks like tulipwood....
Re: latest work
Re: That looks like tulipwood....
Don Evans
Agree, looks like tulipwood that I have in stock.
Re: latest work
Don Orr
Which in the Dalbergia genus with rosewoods-well known to be allergenic.
Re: latest work
Using the fibonacci scale
Dick Coers
The base should be 3/5 of the height, the top should be 2/5. Yours looks quite the opposite.
Re: latest work
Re: Using the fibonacci scale
GaryG in MD
Dick, I appreciate your opinion, but I'm going to have to disagree, thrice.
First, I wasn't doing Fib.
Second, the math doesn't say which part gets which dimension.
Third, IMO, that would be way too delicate.
Not at all the effect I wanted.
Here are some examples from Cindy that are more in keeping with my vision:
https://img.yumpu.com/32624780/1/358x459/finial-design-article-cindy-drozda.jpg?quality=80
https://s-media-cache-ak0.pinimg.com/236x/c1/78/c8/c178c89f0961ecf8e2705ba46ce9c18b.jpg
http://www.cindydrozda.com/images/artwork/9443CarterWEB.jpg
http://2.bp.blogspot.com/-3KOPw6zkbhE/Uh-Yd5tz6QI/AAAAAAAAAQ4/4knyO4RRbiQ/s1600/12541ozGoddess4WEB.jpg
...GG
Re: latest work
Dick Coers
Your last paragraph of the original post suggests you weren't content with the proportions. The math always works if you want to use it. The hollow form height is proportional to the finial. The major elements of the finial are proportional to each other. The break in the hollow form is proportional to the height of the vessel. If you place a Fibonacci caliper against your piece, the lower section of the caliper would be on the table and the second arm should be on the top of the hollow form. The outside caliper arm would be on the top of the finial. Here is an example on a glass piece I purchased. The same thing works for a coke bottle, where designers place the name on a can of beer, etc. Walk around your kitchen with a caliper and you'd be amazed how close it comes to simple items purchased at the grocery store. It's done because the proportions are pleasing to the eye. If you want to make the finial a foot tall, it's your prerogative. Sorry about the poor photo quality, I needed a third hand.
Re: latest work
Mike Darlow in "Woodturning Design" makes a good case for why the math can be a fuzzy.
Re: latest work
GaryG in MD
Dick,
I appreciate carrying on this discussion with you.
With all due respect, your example is a "knob" to me (regardless of the shape) and not at all what I wanted in this case.
The four images I attached of some finialed pieces made by Cindy are much more what I had in mind here.
My intent was not to use Fib. proportions here (not that I disagree with their use in some cases), but I had some other criteria (below). I might add that you could turn your Fib. caliper around and make your knob taller than the body, too -- there is no rule about which proportion goes where.
My comment about proportions in the original post was more to the effect of perturbations. The body is 5" in diameter by 2-1/8" high. I decided to make the finial the same height as the body diameter. My first design had the finial only 4" high, but it looked stunted to me. As I have said to John, the 2D photo, shot from the height of the finial, rather than the body, makes it appear more extreme. In real life in 3D from a "typical" viewing angle, the finial does not dominate the appearance nearly as much as it does in that photo.
If we want to talk about "magic" numbers, the body height is just barely under one-third of the total height (the old "rule of thirds" trick), and I prefer being "slightly under" when so much "air" is involved -- it not being a solid rectangle.
Thanks for your thoughts. All good. ...GG
Re: latest work
Nitty-gritty wood ID
GaryG in MD
Thanks Brian, Don, and Don for your comments.
They are very well taken, regarding the padauk vs. tulipwood question.
It would make a LOT of sense if that rolling pin were really tulipwood.
But it's not -- it's really padauk, and I'm quite allergic to it (which is not a big surprise if you read the literature on padauk).
I have checked the microscopic pore structure.
Exotic tulipwood (dalbergia) has a more ring porous structure, while padauk is more diffuse porous. I might add that there are a number of different kinds of padauk (per, for example, Mark Baker's book "Wood for Woodturners").
Also, although we normally think of padauk as being a uniform reddish brown, that's not strictly the case. Here's a good example of the variegated version from Hobbit House:
http://www.hobbithouseinc.com/personal/woodpics/padauk/padauk%2015%20s50%20plh.htm
Go about a third of the way down or see photo here below.
This is a great database, if you're not familiar with it.
Regardless of the rolling pin, I still agree that the finial looks a lot more like padauk to me than canarywood! I certainly agree with William on that count. And I have no inherent trust in that seller, so I really shouldn't have turned that piece of wood without looking at it more carefully! Duh. Luckily, I must not be allergic to "that kind of padauk" like I was to the variegated kind. Whew. Dodged a bullet. This is a good warning to you all -- if you're turning an exotic, make sure what it really is first!! And, yes, watch out for those dalbergia species! But padauk is not for everyone either!
...GG
Re: latest work
Re: thanks, Brad
William Duffield
I have both padauk and tulipwood in stock, and in finished pieces. The label on my padauk doesn't say which species. There are saveral members of the Pterocarpus genus. The rolling pin in your picture is padauk or something closely related, but not tulipwood.
It is interesting to compare the descriptions and pictures of the elated species linked from this page:
http://www.wood-database.com/african-padauk/
And, then, some bad news that you're all just going to have to deal with: http://www.wood-database.com/wood-articles/preventing-color-changes-in-exotic-woods/
Re: latest work
Re: thanks, Brad
GaryG in MD
Agreed! ...GG
