Stewart Batty 40/40 grind with Wolverine jig
I did a little experiment today trying to answer a question on using a jig to get the Stewart Batty 40/40 grind. You can get close using the Wolverine jig set up as shown in this photo. I was using a Henry Taylor 1/2" U shaped bowl gouge. Others gouges might change the grind. Also depending on your wheel size you may or may not get a true 40/40, might be 45/45.
Set the tool in the jig with 1 3/4" extended. Move the moveable arm so the top side just matches the highest notch in the Wolverine jig. Then set the V arm to a distance that will grind the nose to 40 degrees. This should come really close to the Grind Stewart Uses.
