square routed ornament.
I'm still making some square ornaments. For this one I routed 24 grooves in each side. I turned a recess in each side and then set up the router so in ran out near the middle. Then cut the grooves below center so they appear to spiral. Painted it gold and then used an ink brayer to paint on some red. Then added a raised gold dot to the center with PUff Paint. About 1 3/4" square.
Re: square routed ornament.
David Walser
Cool affect. Any chance you could do a video on the technique? I can promise you at least one viewer!
Unique and eye-catching!
Now I'm waiting for the square, routed, inside-out, 6-way hollowed, carved, gilded and pyro-enhanced ornament (with a hand mirror inside!)
Brad Vietje
Make That at Least TWO Viewers!
