Wood Tool Parts
Wood Tool Parts
Wood Tool Parts
mikeee12345
I was looking on the internet for some hardware to finish some wood turned handles.
Is there a technical term for the metal end caps used on the ends of some lathe turning tools.
I could not find a good word to use that would bring up matches for the (ends, bumpers, pommels).
Re: Wood Tool Parts
Lyle Jamieson
Re: Wood Tool Parts
Lyle Jamieson
Ferrul
Re: Wood Tool Parts
Re: Wood Tool Parts
Brian Roberts
fer·rule
ˈferəl/
noun
--a ring or cap, typically a metal one, that strengthens the end of a handle, stick, or tube and prevents it from splitting or wearing.
--a metal band strengthening or forming a joint.
Re: Wood Tool Parts
Re: Wood Tool Parts
mikeee12345
Would they refer to the metal piece on the butt end of the wood handle as a ferrule also?
I tried using ferrule as a search term but could not find the type of items I am looking for.
It seems like most tools tend to come up with a special term for every component.
Re: Wood Tool Parts
Re: Wood Tool Parts
William Duffield
No, the ferrule is on the end with the tool, as noted, to prevent splitting. The cap on the other end is just there to hide the tool marks from the turning center, so they can make it cheaper.
You might try "bling." :D
Re: Wood Tool Parts
Dennis in Southern Oregon
Re: Wood Tool Parts
I never buy ferrules for shop-turned tool handles. I make them in minutes from short pieces of copper tubing or copper collars. An alternative is to buy octagonal brass compression nuts and turn them round on the lathe using a parting tool. (They turn rather easily.) The nuts are available in a wide range of sizes and have the advantage that they can be threaded onto the end of wood handle for a positive grip. The photo shows a few examples from my shop. The ferrule on the parting tool in the foreground was made from a brass nut.
Re: Wood Tool Parts
Re: Wood Tool Parts
mikeee12345
I am wanting to dress up the back end of the tool handle with a (button, bumper, pommel).
Just can't find any matches to the terms I have tried.
Re: Wood Tool Parts
Re: Wood Tool Parts
Jeff luedloff
turn a button out of a contrasting wood-
use a carriage bolt-
I have seen a carriage bolt used on wood handled chisels, cut the carriage bolt so it seats through the handle butted up againt the tang of the chisel-so if you strike the chisel with a hammer the force is seated against the metal part of the chisel-
Re: Wood Tool Parts
Re: Wood Tool Parts
Check your hardware store. I believe that I have seen decorative brass buttons (actually tacks) that you can hammer into wood.
Re: Wood Tool Parts
Re: Wood Tool Parts
Stuart Johnson
Do a Google search for brass or copper end caps.
Re: Wood Tool Parts
Beg to differ....
Brian Roberts
but a ferrule is a ferrule.....the job it does earns the name....matters not which end of the handle it's doing that job on.
Re: Wood Tool Parts
On a hand plans Strike Button
I Vaughan
Have seen strike buttons of brass or dense wood on some hand chisels. should work as a decorative element or to protect the handle it forcefully setting a tapered tang.
Re: Wood Tool Parts
I did a lot of searches
Could not find the right words to bring anything up. What I would suggest is getting some brass rod on the diameter you want and just turn your own. easy to do with HSS turning tools.
Re: Wood Tool Parts
Similar to strike button
Dick Coers
I suppose those were first used on turning tools that had a tapered shank on the chisel, set into the handle. With some vibration and wood seasonal movement, the turner would need to bang that end of the handle on a hard surface to reset the chisel. The end button would prevent any splintering or damage to the handle. You could use a short connector bolt or nut, but they would have an internal hex hole on the end. A cheap solution is an electrical box blank knockout seal.
Re: Wood Tool Parts
Re: Beg to differ....
William Duffield
If there's no tool jammed into the butt end of the handle, there isn't any splitting force for the bling to counteract. We're not talking about double-ended dental pics, for example, that have tools on both ends.
Re: Wood Tool Parts
Re: Wood Tool Parts
William Duffield
I think you might find something that will work if you search for "upholstery tack" or "decorative brad"
Re: Wood Tool Parts
Re: Wood Tool Parts
William Duffield
"Dome of Silence" glides might work, too.
Re: Wood Tool Parts
Ummmm.....
Brian Roberts
Japanese...and other....chisels routinely have a ferrule at both ends of the handle.
The only question was what it's called IF used to prevent wear and/or splitting.
That....my friend makes it a ferrule....to answer the original question.
Re: Wood Tool Parts
So....
Brian Roberts
what exactly are you wanting this thing to do?
You are not referring to the ferrule at the cutter end of the handle.
Are you just looking to decorate the other end?
Re: Wood Tool Parts
Re: Ummmm.....
William Duffield
I think, in that case, it's called a hoop or sometimes a striking ring.
Re: Wood Tool Parts
Jim Evans
Re: Wood Tool Parts *LINK*
Jim Evans
Parts of a wood carving chisel.
https://www.wonkeedonkeetools.co.uk/wood-carving-chisels/what-are-the-parts-of-a-woodcarving-chisel/
Re: Wood Tool Parts
It's to cover the mark from the live center
When I first started turning handles I would drill the hole first and then I had a drive center that fit in this hole. I would bring the tailcenter up and turn the whole handle. When I removed the tailcenter there was a hole so I just drove a brass tack that I had handy into that hole to cover it up.
Now I do things in reverse. I have custom made hole sizes for my live tail center and I put the predrilled hole of the handle on that. Then I turn the rest of the handle but the butt end will end about 1/2" or so from the drive center. Then I cut this off and carve it away and there isn't a hole.
Re: Wood Tool Parts
Jim Barbour
Re: Wood Tool Parts
Jim Barbour
On a chisel a solid end-cap for striking is sometimes called a bolster, but more often a butt plate, as it is on the butt of a rifle.
I suppose the term bolster shares its origin with the bolster on a muzzle loading rifle - there is a part of the lock called the bolster which serves a similar purpose at the back of the lock (it is the restraining piece which effectively forms the back end of the barrel, sometimes screwed in place, more often an integral part of the lock casting.
Also, when a ferrule is put on the butt end of a tool it is often called a hoop, even though it is exactly the same thing as the ferrule on the tool end.
