Apple Wood turns into Pine Wood
mikeee12345
Grabbed a bowl blank from my outdoor inventory to rough out this morning and was sorting through the different blanks I had processed earlier in the year. With all of the exposed grain covered with a sealer and each one identified with a species written on the flat end of the blank I chose an apple wood blank.
Mounted on a flat face plate I began roughing the outside so I can machine a recess for my bowl chuck,
I noticed the wood chips and dust were sticking to my arms and shirt and bluejeans.
Turned the lathe off and noticed the wood grain was pine and not apple.
Someone has apparently been switching my good quality Apple bowl blanks with common Pine bowl blanks.
Filling out the police report right now. :-)
Re: Apple Wood turns into Pine Wood
Couldn't you smell the difference
Dick Coers
You should have known the instant the chisel touched the wood.
David Walser
I'm sure the perp is guilty of not just swapping out apple for pine, he's also guilty of forgery. I suggest you have the handwriting noting the type of wood on each blank compared with handwriting samples taken from your home. I'll bet you'll find the same person has been writing checks drawn on your account!
mikeee12345
You know I was asking myself the same thing while turning the blank.
Usually Pine has a very strong odor which is readily identified, this particular
wood had some blue staining from the Pine beetle and the smell was a little
different from most Pine woods I have turned. I make a lot of wood forms
and molds out of Pine lumber and the smell was nowhere close.
I have been adding to my wood inventory each year and processing multiple truck loads
of wood each year, so I can have a good inventory of dry wood blanks when I retire.
I usually put several coats of sealer on the end grains which requires remarking the wood
blanks after each coat is applied. I try to use different colors of latex paint as a sealer so
I can readily identify the wood blanks by color and sort them.
Twelve hours of unloading, transporting, cutting, sealing a load of wood, you get a little
tired and lose focus towards the end of the day.
Old Timers Disease kicking in! :-)
Brad Vietje
Re: Couldn't you feel the weight difference?
Brad Vietje
Apple is WAY heavier than Pine. Should have been a dead giveaway. I turned them both yesterday, BTW, and yup -- Pine shavings do seem to stick - static electricity?
Safe Spinning,
Brad Vietje
Newbury, VT
Brad Vietje
12 Hours?  Time for beer, not turning!
Re: 12 Hours?  Time for beer, not turning!
mikeee12345
I have have a big truck. :-)
Processing an entire load of wood in one day is a lot of work!
I did get some wood turned today, took a day of vacation.
Apple, pine?
I've wondered what it was like to turn pineapple.
John, does the word "refreshing" come........
JamieDonaldson
...to mind? Then add sticky, messy,......... :D
mikeee12345
If you are turning freshly cut wood the weight would be a give away, but I have a collection
of wood that has been added to for a number of years. Most bowl turners will process wood
as quickly as they can to avoid checking and cracks. I turn a large number of solid billet tools
used for a specialty trade which requires laminated billets or solid billets for the items. Depending
on how old the billets are the weight can vary a great deal between a dry billet & wet billet. I have to
seal the exposed wood grain so it dries slowly and does not crack or check. So trying to identify a wood
species by the outer bark can be a challenge at times.
