Dremel repair
I have a lot of Dremel and some of them needed some repair. I was going to replace the bearings in two of them. Apparently you have to buy the whole rotor assembly. It's kind of expensive. I ordered one and replaced it. Now I'm going to try and get this one apart and replace just the bearings. The problem on this style is it appears that the threaded end is pressed on. The hole you see is for the lock pin so I don't think it's there to thread the thing on but I could be wrong. Has anyone taken this apart before. The other bearing should be easy to remove from the other end if I fabricate a small bearing puller.
The other dremel has a bad switch and I've tried cleaning it and it won't work so I will have to replace it at a cost of $24. Don't know if I'll do that because I can buy these dremels at the flea mkt for as little as $15 if I look hard enough. I should be able to swap some parts out and keep one of them working.
