3520b storage cabinet?
cameron
I noticed that my lathe has some cast in brackets for shelving/cabinets between the legs. I see remarkably little on google in terms of pictures of people putting cabinets in this spot and I'm wondering if this is a good idea (needing to find a place to store lathe-related stuff.) I'm wondering if it would get in the way of legs/feet and thus should be avoided? Any other pitfalls like clean up issues etc?
Thanks
If you plan to fill it with sand, make sure you build a sturdy, well sealed box. Otherwise, with any residual vibration, the sand will find its way out and onto the floor. It helps if you make the lid sloped, so it doesn't fill with shavings. No need for hinges. Just screw the top down. The higher the center of gravity of the ballast box, the more effective its weight is at dampening vibration. The only problem with using the top of the box as a temporary resting place for tools in use is that they tend to disappear under the shavings. Bowl gouges are easier to find than calipers, so I attach calipers and other mall stuff to the lathe bed, motor or tailstock with rare earth magnet instead of setting them on the ballast.
