Re: Enhanced staining color
David Walser
I don't recall the post, but I'm familiar with the technique. Some woods, such as cherry, do not take stain evenly and prone to blotching. To avoid this, some woodworkers partially seal the wood with shellac. When it works, it works. When it doesn't, it's apt to make things worse. (Think about it: If you put too much shellac on, the wood won't absorb any stain. If you put on too little, you'll still end up with blotching. But, if you're Goldilocks, you'll get the finish you desire. Takes practice to get it right.)
Instead, try wood stain conditioner, preferably the one sold by the maker of the stain you're using. You're much more likely to get a good result.
HTH
