Re: PITT markers are excellent
Jerry Maske
For what it's worth, I make Basket Illusions and need a LOT of colors. Harvey Meyer talks about that in his videos, but I've come to my own conclusions, and it goes like this.
Take a piece of scrap wood you plan to make your bowl from and put on random designs in Sharpies, Faber Castell or whatever else you can find; Walmart has TONS of them. Coat them with your favorite flavor finish AFTER the marker has dried.
Then you can see what you're dealing with. In the Basket Illusions, the wood burned areas stop bleeding, and if I let things dry over night and coat with at least two coats of something, I NEVER have bleeding or smearing.
But I think the answer is to test, test and test. I sometimes use Krylon spray, several coats, and it seems to stop all deterioration. But there's more than one way and more than one approach. If you check my latest picture, you'll see at least three different brands of markers that DON'T smear or bleed. I tested them all before I used them and am very happy with the results.
Jerry
