Spheres and cup centers - Pen turning related
Craig Daymon
I have a set of #2MT plastic pieces for pen assembly. One in the head stock and one in the tail and advancing the tailstock presses the pen parts together.
Thought it was from Penn State. Can't find where. They have conical shaped ends, helping to center the pen parts.
I suspect these would work perfect for holding a sphere for final shaping/sanding, or could easily be lightly turned to create more cup-shaped ends. Again, I don't remember where I got them. (Maybe Lee Valley?) They were cheap.
Might try using them today.
Re: Spheres and cup centers - Pen turning related
Re: Spheres and cup centers - Pen turning related *LINK*
David Walser
Craft Supplies USA sells what you were describing. They call it the Artisan Pen-Ultimate Assembly Tool. I have it and like it for assembling pens. I find it more precise and easier to use than a pen press.
I've not tried it for use as a cup center for turning spheres. The "tool" mounts in the Morse tapers of the headstock and tailstock. You'd have to figure out away of mounting the tailstock part of the tool onto a live center to use it with turning a sphere.
Dick Coers
I'm guessing the conical bore angles are wrong and too small of diameter for wood spheres of much size. Ideally the contact area for working the spheres is some distance inside the adapter. But I don't know if you are turning wood marbles or 3" spheres.
Craig Daymon
That's probably where I got them.
Good point about the revolving center for the tailstock. Thought there must be something I was missing.
Craig Daymon
I usually turn about a 3" sphere. Nice size to hold and to turn.
In an ideal world, one would have perfect cup centers matching the inverse curvature of the spheres they are creating, because that would give you the most contact. I suspect that rarely happens, and turning such a cup is much more challenging than turning a round sphere. (Especially if you are not concerned about an exact size, as is the case with the spheres I turn.)
With my cup centers, I really only worry about a ring of contact on each with the spheres. A conical indentation in the cups would actually provide accurate centering between the cups and that ring of contact for a variety of sized spheres.
Softness of the material is more an issue for me. UHMW turns well, but can be hard and unless the wood/material is nearly as hard or harder, you can get compression marks if you tighten too much. I bought some ureathane to try to turn softer cups, but it doesn't turn or thread all that easy. Plan to make the threaded part (for headstock and for live 3/4"-16tpi center) out of UHMW and then make cups to put on these from the urethane. Haven't done so yet.
