Re: bought a 3520b
Ivan Clark
In my prime, I probably could have gotten away with disassembling a 3520B and getting it into the back of a pickup by myself. Now-a-days, there is no way that I would try to do it by myself.
I brought one back from Tampa in a minivan so I have been through the disassembly/assembly process. So, here are some suggestions:
1) if the bed of your truck is like most, put a sheet of plywood down in the bed to slide the lathe parts around on. The headstock paint will thank you.
2) you will need some tools to remove the legs and accessory bracket
3) you want to take a sturdy sawhorse that is slightly taller than the distance from the underside of the ways to the ground.
4) take a ziplock to put screws and small parts in
Disassembly:
1) remove accessory brackets, guard cage, any chucks or centers, and toolrests
2) remove stops at ends of ways
3) remove tailstock and banjo
4) remove headstock and place upside down in bed of truck
5) line the ways up to slide into truck
6) place sawhorse under ways at truck end of ways
7) remove legs from truck end of lathe.
lift and slide the bed so that the end is sitting in the truck
9) remove sawhorse
10) remove other set of legs
11) slide bed into truck
12) secure all of the parts of the lathe in the truck
When I moved mine in the van, I screwed stops to the plywood to keep the parts from sliding around.
for reassembly, 2 sawhorses are a good idea.
Putting the headstock back on was a challenge for 2 of us. We failed to take a good look at the nut plate that has to be lined up with the underside of the ways when you are installing it. It is also heavy, has to be flipped back upright, and there are few good palces to lift by.
I got the caster set that Craft Supply sells for the 3520B and they work really well.
