I've been busy lately
Well I've had a lot of work to do lately around the house but I've had time to do some turning.
Re: I've been busy lately
mikeee12345
Nice work John!
You have been busy! :-)
A few more
More of the Executive Baby rattles with captured rings inside. The angel was a screw up. I was trying to answer a woodturners question on the phone and forgot where I was when turning the angels. I turned most of the head before hollowing and finishing the skirt. So now it was chattering. Usually I would just make light cuts to get rid of it but I decided what the heck, I'll just push on the bevel harder and create more chatter. You can't sand that but the cuts were clean enough that I just painted it. I found some gold glitter spray and hit it lightly with that.
Busy like a beaver...
Don Orr
... chewing up the wood. Great work as always!
Jake Niedling
Hey John - nice work as always. What is the texture/color finish on the block ornament?
Jake
John C Lucas
Copper rubnbuff
Wow! The cube especially caught my eye. Is that an original design?
I'm still turning colored acrylic. I'll bring some to the club meeting.
I really like the cube John, and wonder how.....
JamieDonaldson
....you chucked it for turning all sides?
Jake Niedling
It looks like you have textured it with something like an engraving tool with a rounded tip as well.
Exactly. This was just a horsing around piece from a square piece of scrap. I just stuck it in a chuck and turned a sort of shallow bowl in each side to see what would happen. It started getting cool when I cut into the sides of each bowl. This piece of wood wasn't exactly square and I didn't make the bowls exactly the same size so the holes are all different. Since I chucked it straight into a 4 jaw chuck there were teeth marks near all the corners. So I disguised them with the Dremel engraver and a rounded over bit. Now that I know what happens I may make a smaller one (this one is huge) and try to make each bowl exactly the same shape so the interior holes will match.
See the reply to Jake above
Re: I really like the cube John, and wonder how...
I like the cube too. I have a round nose router bit about an inch and a half in diameter and I use it to hollow little bird houses. It would do a good job of this, If I could find it. Its hiding at the moment.
My other thought/question is what would happen if you drill through the center form one of more directions with a smaller bit?
Barry I think someone wrote an article possibly for Woodturning Design on a square ornament that was drilled from 4 sides and maybe a little turning but I can't remember it well enough to think up the details. I saw some of the when I visited Robert Vaughn in Virginia. He had made a dozen or so but that was 3 or 4 years ago.
