REAL MILK PAINT
Screw choice for END-GRAIN Bradford Pear?
Keith Newton
I haven't done any end grain-turning in years, and was a bit concerned about the screws holding in end-grain, so I went with 2" #10 sheet metal screws, the longest in my bins. My face plate is 3/4" thick, so that was 1 1/4" penetration, with what I thought were really tough screws. But driving the last of 6 screws, the head twisted off, so I put another in the nearest hole 1/2" away, then screwed it on the end of the headstock.
As I was cleaning up around the lathe, I found some 2 1/2" #14 screws, and set about changing them out. But when I got on them with the impact driver to remove them, 4 more heads twisted off. When I tried using vice grips on the stubs sticking up, they all broke off above the surface, even after putting a torch on a couple getting them red hot, which is a good trick on dry wood, but probably a wasted effort on wood this wet.
I know that the sheet metal screws that I used to get were a lot tougher than this, but who knows nowadays where they come from and to what standard.
I think I have some coated deck screws that should be tougher than this.
What do you suggest, is Stainless Steel the way to go? I'll wax the next ones to aid getting them out.
Re: Screw choice for END-GRAIN Bradford Pear?
mikeee12345
No fun digging broken screws out of a wood piece, stainless steel screws would be a better choice to provide holding strength while turning on the lathe and not break when installing or removing the screws from the wood piece.
Rarely
use a face plate any more, but wet or dry I use #12s that will penetrate 1" or more into the wood. Deck screws are too thin, usually #8 and too weak to handle the stress from a turning. My FP's are 1/2" thick and are double countered so I'll use 1-1/4 to 1-3/4" flat-head screws waxed. Lastly, I prefer to use the drill with the clutch backed off rather than the impact driver; easier on the screws and they hold better because you're not twisting them beyond their maximum grip point. The impact will torque too much and actually fracture the wood fibers turning the screw into a drill bit so you get less holding power.
That said, I start everything between centers so that I keep the option to adjust the rotational center and better balance the grain. For end grain work I'll cut a tenon to fit the DT jaws in the scroll chuck, especially in wet wood.
Doing a bowl or a jar?
Pilot Holes for End Grain
Doc Green
To get the best holding power in end grain wood: 1. Always drill a pilot hole; 2. Do not over-tighten the screws. (As Mark said above.)
I ramble on at length about it here:
http://www.docgreenwoodturner.com/screwendgrain.html
Good luck. ~Doc
Re: Pilot Holes for End Grain
Keith Newton
I did drill pilot holes, and obviously must have over tightened the first. However all the others broke off while trying to remove them, and even after the heads broke off, there was plenty left to get a good grip with vice-grip pliers, but they broke again.
Sometimes the wood can really seize onto fasteners.
Excellent article Doc-as are all or yours
Lyle Jamieson
Lyle Jamieson
Its not the length of the screws that will give you support it is the number of screws. I use #12 pan head sheet metal screws 1 1/4 inch long. But 10 or 12 screws in each faceplate. I have never had one break. I always use an impact driver. I only pilot hole dry wood. Pilot holes in wet wood end grain risks stripping the threads.
How long did you leave the screws in before you tried to remove them??
Use #12 screws because the heads are for #3 Phillips. They don't strip the heads while screwing and last many times before the socket gets scarfed up.
Not very long
Keith Newton
How long did you leave the screws in before you tried to remove them? The screws were not in the wood over 15 minutes.
Just to make it clear, my problem wasn't that my screw to wood connection failed, it was just the opposite. I felt the screws must have been faulty, and failed / broke too easily.
I think it would be safe to say that all woods aren't the same, when it comes to screws into end-grain performance.
Lyle Jamieson
Re: Not very long
Lyle Jamieson
The wood variety has very little difference in using the faceplate method. I have done the same method you describe thousands of times in wet woods of all varieties with no failures.
Re: Excellent article Doc-as are all or yours
Bill Turpin in WNC mountains
AMEN!
I have used pan head sheet metal screw Lyle describes and had no failures.
I have also used Tapcon screws meant to driven into concrete with no failures. For these I countersunk the holes slightly so I can use either pan head or countersunk screws.
You are right about the quality control though.
Re: Screw choice for END-GRAIN Bradford Pear? *LINK*
walta
Every screw manufacture balances hardness vs. toughness in their product. Both are desirable properties but generally as hardness increases, toughness decreases.
Hardness is the ability to cut into concrete or steel without damaging the threads on the screw.
Toughness is the ability to bend without breaking.
I test the screws I use on face plates for toughness by clamping half in a machinists vise, hit the screw with a hammer if it will bend 45° without snapping you have the correct screw.
Understand the tough screw will most likely fail because the Philips head will strip. I look for square drive screws.
A hard screw is very dangerous, because they will snap without warning letting the wood fly.
The only thing stainless offers is rust resistance at the expense of both hardness and toughness.
Craft supplies
Lyle Jamieson
Lyle Jamieson
agree there is a balance there. I do not like square drive with a impact driver. The bit sticks in the holes and is a pain. The # 12 screws use a #3 Phillips and they are much sturdier than the #2, that strip easily.
Keith Newton
None of my screws failed in the middle, so your test bend wouldn't likely show if you just bent it in the middle. I think you should also grip the head, and try to bend at the thread end, where all of these failed.
As for hardness and toughness, I think the subject is a bit deeper than your statement. Just mild steel might bend easy, but probably break easily too. I agree that toughness is what we need, and what I was hoping to hear about what others are using.
Back in my early years, I thought I would just bump on up and use Lag Screws. I quickly found out that 1/4" lags will break where the thread starts if you just look at them wrong. Lags might be fine at 3/8" and above, but then going that large would probably lead to other problems like splitting along the grain due to more wedging if the pilot hole wasn't sized properly.
I agree with Lyle, in that I had looked for the larger screws, which were loosely resting in my 10" faceplate, rather than making it back into a little tray where I normally keep them. After starting with the #10 screws which had #2 phillips that failed, I replaced them with the #12 pans.
Doug Ladendorf
There are two quality screw brands I like that can be found at Home Depot:
Tapcon http://m.homedepot.com/p/Tapcon-3-16-in-x-1-3-4-in-Philips-Climaseal-Steel-Flat-Head-Concrete-Anchors-75-Pack-24355/100136988
GRK Fasteners http://m.homedepot.com/p/GRK-Fasteners-8-x-1-1-4-in-R4-Multi-Purpose-Screw-110-per-Pack-96080/204837653
The bigger GRK can substitute for lag bolts. They are great.
Brad Vietje
'Nuther Vote for GRK...
Brad Vietje
GRK makes a wide variety of fasteners. I only use the #8 screws for small, lighter work, but for 150# Aspen lamp shade blanks, I use their 1/4" x 3-1/2" and up through the bad boys that are 5" long. These are amazingly strong; tough w/out being brittle. (I had to demolish a temporary construction stairway that was made from 2x6's and the #8 x 3" screws, and I can attest that you can beat the living hell out of these, and they will bend a long way before they break. I gave up trying to break them apart with a #14 sledge hammer, and resorted to cutting them with a Sawzall and a metal blade.)
GRK is hardened steel that are very tough (some are available in stainless, which is not as strong). They use a TORX head, for great "grip" w/out stripping. For sheet metal screws, do get some that are #3 Phillips, which are many times better than the standard #2 Phillips -- I think Lyle suggested that(?), and I will agree.
Safe spinning,
Brad Vietje
Newbury, VT
Jim Barbour
Jim Barbour
How about SPAX screws? HD and McFeeley's carry them, as I am sure others do as well. I've used them in side grain, but not in end grain.
http://www.spax.us/
r thomas
Why not use a chuck? I use a chuck on hollow forms up to 14 in and around 80 lbs.
