traditional vs irish grind
I had a chance to do an experiment the other day. Some say the traditional grind cuts cleaner than the irish grind. I am having trouble seeing this since i feel the rounded area doing the cutting is just about the same on both gouges is the flutes are held at the same angle.
I reground 2 homemade gouges to the exact same angle but ground one as a traditional grind (some what like a spindle roughing gouge) and ground the other to an irish grind (some what like Ellsworth grind and other names applied)
I also use a Hunter Osprey that had a well used cutter in it. I got virtually the exact same cut with any of the 3. I was very dependant on the forward feed pressure. Just a little too much and I got some tearout with any of the 3. Just right and they all cut the same. Just for fun I put a new cutter on Osprey and resharpened all the gouges. The Osprey cut cleaner, the other 2 exactly the same.
Now I haven't done a lot of cutting with the traditional grind although I have Stewart Batty grind which is very similar I use a lot. I find the actual sharpening angle and the way you use the tool is more important than the grind. At least in this case.
