Found a good deal on powermatic lathe
Braden
Anyone looking for old iron:
https://columbus.craigslist.org/tls/5705774918.html
Not my ad, but stumbled upon it. These gems with mispellings often lead to good deals
Braden
I wouldn't pay that for that lathe
Dick Coers
Hate the gap bed, reeves drive, and small diameter capacity.
Re: I wouldn't pay that for that lathe
Gap bed isn't as big a problem as they used to be. Most of us are using chucks now and that moves the work out to where the gap bed isn't as bad. I used to hate them also but I've had to demo on one similar to this several times and it isn't bad. The Reeves drive is a pain if you forget to slow it down before you stop. It always starts at whatever speed you leave it at.
Re: Found a good deal on powermatic lathe
Lyle Jamieson
That lathe was made in the 1970's, has been painted. Maybe the existing owner never used it but it is likely very used. I think the price is the going rate for these. But I would never get it, the obstacles and limitations will drive you crazy. Pay for a good lathe, you are worth it.
buy a 12" midi new lathe
For that kind of money you can get a 12" midi lathe that will let you turn the same things that will except for long spindles. You will have a better variable speed on the new lathe and it will take all of the modern accessories. There is a good possibility that that lathe has 1 1/2" spindle and 1 1/8" tool post. Neither one are standard today.
Re: buy a 12" midi new lathe
Lyle Jamieson
It does not say if it is a PM 45 or 90. But both will have compatibility problems with standard accessories. They were all 3 phase too. How was it converted?? Sooooo many issues with an old lathe like that.
Roy Girolami
That's a PM90 and it does have a 1 1/2" spindle and 1 1/8" diameter tool posts. Those are very good spindle lathes but the swing is limiting. i liked how the pictures showed they painted it on the trailer.
Roy
Maybe they took it to Earl Scheib ?
Dick Coers
Any color lathe for $29.95!
